Crank Pully Picture
does anyone have a picture of what the crank pulley should look like? is it just black rubber or does it have groves on it?
Re: Crank Pully Picture
Bam!
97 Toyota 4Runner SR5, 5 spd 92 Ebony SVX AWD (4.44 gears) |
Nice thanks for the pic....not what mine looks like. ok I need to find a pulley now. anyone in sepa, nj, or leigh valley have one they want to sell
I just installed a light weight crank pulley so I no longer need my original I can send it to you in the mail. Probably wouldn't make it out until Tuesday and then a day later for delivery so Wed. unless I make it to NJ for something else I suppose.
sowise, thank you for the off but I thought it best to get a light weight one also
I had to replace a Crank Pully recently and the local Subaru auto wrecker didn't have one off an SVX. He sold me one from another type of Subaru (Legacy I think) and it was the exact same part. For what it's worth . . .
Would a crank pulley off a 94 work on a 92 at all
If you did some searching you would find that any SVX crank pulley is interchangable as well as any crank pulley off an EJ series 4 cylinder
What size socket would I have to use to get that Pully off metric would be preffered
"What size socket would I have to use to get that Pully off metric would be preffered "
Seriously? um, bigger than 10mm and smaller than 24mm.... It isn't that hard to figure some of this stuff out without having to post it. I believe it is right around 19mm but I could be wrong. Just take a minute and a socket set and do it, besides there is nothing like a little trial and error to gain some experience. |
22mm I believe. I am pretty positive too.
Let's not throw stones. Some socket sets don't go past 19mm, and it is not fun to go buy another set and it just happens to have the size you need omitted. There is no such thing as a stupid question.
Wont lightweight pulleys set off the balance for the crankshaft?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Not if the pulley is balanced. The balance means that it is rotationally balanced. I do not believe that it matters where the CG is, as long as its close to origionally designed. I could be wrong though.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
i guess so, it could've been just a domestic V8 thing that was causing issues as well with the harmonic balancer
Thread Tools | |
Display Modes | |
