Old 01-13-2010, 10:39 AM
92_LSL's Avatar
92_LSL 92_LSL is offline
Question just wondering (pistons)
can you use ej22 pistons to lower the compression of a eg33 so you can boost it ??? i dont know how true this is but hopefully somebody can give me some helpful advice. i really want to boost my svx but i need lower compression pistons to do this, and i know ecutune makes them but need a cheaper alternative.
Old 01-13-2010, 12:22 PM
Re: just wondering (pistons)
The search tab is your friend... otherwise if you want to find out about turboing the EG33, go in the engine mod forum... you will find everything you want to know
Old 01-13-2010, 03:51 PM
92_LSL's Avatar
well i heard many things are similar between the eg33 and the ej22. i just want to know if they are compatible.
Old 01-13-2010, 04:06 PM
Old 01-13-2010, 05:28 PM
92_LSL's Avatar
the link you gave me did not work.
Old 01-13-2010, 07:17 PM
taylorbr's Avatar
taylorbr taylorbr is offline
From what I've read, the EJ22 pistons will work, but they lower the compression ratio quite a bit...going off memory, but I think it was somewhere in the 7's.
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
