Old 09-30-2009, 01:29 PM
major7venth's Avatar
major7venth major7venth is offline
M7
No shift from 1st gear.
Long story short... used 92' trans, installed in another 92',..will not shift out of 1st gear. Neutral, reverse, park are ok.. no TCU codes although, only able to drive about 25mph. Service Manual points to solenoid 1. Anyone ever experience this problem??
Old 09-30-2009, 05:13 PM
Re: No shift from 1st gear.
Won't be a shift solenoid, or it would be using only 3rd. More likely the speed sensor not telling the TCU that the car is going.
Old 10-01-2009, 07:37 PM
well no codes ,no flashing power light ? its not electrical ,if the front speed sensor isnt working you would not have speedo and the rear sensor would tell the tcu your moving but no signal ,but you dont have codes ,the tranny you put in is probaly no good
charlie
