Old 08-13-2009, 06:38 PM
fieronews's Avatar
fieronews fieronews is offline
Fiero Nut Case
Send a message via AIM to fieronews
binding
OK all I got my SVX back and its running with the fuse in the FWD slot and when you take it out the car is binding. so we are driving with the fuse in and it runs great. Now I only have had this car for a few weeks before the trans blew. The dealer put new tires on the front and the rear tires are bald. can the tire situation cause this? He said with the car on the rack and running there is no situation but on the ground this happens so just drive it in front wheel drive mode.
Thoughts?
09 Challenger SRT8
86 Fiero GT
03 PT Dream Cruiser #1801
Old 08-13-2009, 07:47 PM
Re: binding
I would say yes. You need a set of 4 matching tires within 1/4 inch of circumference difference.
Why in the world would they leave bald tires on the back?
Old 08-13-2009, 08:54 PM
Re: binding
From my understanding, the binding is most commonly caused by the Solenoid C on the transmission going bad. That doesn't mean the tranny is shot, just that the solenoid needs to be replaced. Do a search for threads that contain "binding" or a search for "solenoid c" you should find lot of information. After you fix it, get some new tires, -very bad to drive around with mismatched tires.
Old 08-13-2009, 09:23 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Re: binding
Sean is correct but if you have mismatched tires on the back and front it would cause this problem. Get four new tires and your problem will most likely go away.
If it does not go away, let me suggest that you put a small bottle of limited slip differential additive in the tranny. This has cured the problem in two of my subarus -- a legacy and my SVX.
If none of these works than the solenoid C fix should cure your problem.
Some here disagree with putting the limited slip differential additive in the tranny but it worked instantly for me....
BUT I do think it's your mismatched tires that are causing this problem....
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 08-13-2009, 09:40 PM
NiftySVX NiftySVX is offline
Re: binding
Any dealer or repair shop who tells you to drive the car in a mode meant for diagnosis and testing only because they didn't fix the car properly isn't worth a wooden nickel. Take it back and tell them to repair it correctly, or at least diagnose it correctly.
As for not doing it on the rack, there is no way the car could bind on a rack, binding is caused by a difference in speed or lack of difference in speed between wheels, which requires resistance. The C solenoid is very temperamental and fails often. Any shop familiar with a subaru transmission would replace it during any rebuild. A shop not familiar with this transmission would likely not even know it was there and if they did they would not know its function.
If the friction discs are new in the transfer clutch, they may need to be broken in. This would take a week or two of normal driving.
Tell the shop they need to test the transfer clutch apply pressure at the transfer test port as outlined in the service manual or in the transmission manual that is available to transmission specialists.
DO NOT continue to drive the vehicle in FWD mode as it is not designed to operate in this mode except during emissions testing or in rare cases for a limited amount of time.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-14-2009, 04:11 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
I need to save up some cash to get some new tires on it then I am taking it back for them to do there testing. If it still binds then they are going to have to fix it. Now where to get a good deal on some tires?????
09 Challenger SRT8
86 Fiero GT
Old 08-14-2009, 04:28 PM
wyldnwoody44's Avatar
wyldnwoody44 wyldnwoody44 is offline
Mechanically worthless Man : )
Re: binding
Check Tirerack.com they usually run good specials for sets of 4
-92 Ebony LSL, complete with all the problems
-New self paint job; charcol metallic silver
-4.44 tranny,
Nicknamed the SexVX : )
Old 08-14-2009, 04:37 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
Going to have to save a bit looking at
http://www.tirerack.com/tires/tires....omCompare1=yes
292.00 shipped to the door
09 Challenger SRT8
86 Fiero GT
Old 08-14-2009, 04:49 PM
Re: binding
Thats a pretty good price. You could do a little ebay searching, but thats probably the best bet. I usually go with tirerack. I also had some binding issues. The tires can def cause that. However i went with a 4.44 because my tranny was basically toast by time i got the car. Best of luck
-4.44 tranny,
Old 08-18-2009, 07:53 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
Well after some Pawn shop hopping around I now have the money for the tires. So going to get them on tomorrow and get them on and that fuse out. Going to have the trans shop pull the fuse and test and be done with this ordeal
09 Challenger SRT8
86 Fiero GT
Old 08-19-2009, 12:30 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
OK Got new tires on all 4 corners and the trans guy took the fuse out and he said that it felt straneg above 40 so he took it back out. Is he coocoo? Should I pull it and drive it???
09 Challenger SRT8
86 Fiero GT
Old 08-19-2009, 04:01 PM
Re: binding
WHAT IN THE %&## did you just say? it feels strange over $40.00?
Old 08-19-2009, 04:06 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: binding
I think he ment it felt strange above 40mph?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-19-2009, 08:21 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
Ya i have no idea why I put that should just be 40
09 Challenger SRT8
86 Fiero GT
Old 08-20-2009, 01:06 PM
fieronews's Avatar
Fiero Nut Case
Re: binding
you put the thing in AWD mode and you can feel the grinding from the back. Is is posable that there is two diffrent size diffs in the car?
09 Challenger SRT8
86 Fiero GT
