Old 07-27-2002, 10:49 PM
SVX/NSX
Question Steering Problem (Lack of Boost)
Recently I developed a steering problem on my `92 LS-L w/48k mi. I get a binding feel and sqeeling noise when I make a turn from full stop or take the steering wheel to a left or right extreme when parking or making a U-turn. Once the car is moving the steering is responsive, with no binding or issues at city and highway driving speeds. One local shop told me I need a new PS pump, but if that were the case wouldn't I experience a lack of steering assist at all times?
Old 07-28-2002, 08:14 AM
immortal_suby's Avatar
Thread Killah
Go to the personal lockers section o fthe site, then the how-to locker and look for the power steering O-ring fix article and pictures.
Definitely perform that fix before you even think about a new steering rack.
If the steering is still bad I'll trade you my 92 with 163k for yours. I don't have a steering problem.
Locker Link
2015 BRZ Limited 6MT
Old 07-28-2002, 10:29 AM
SVX/NSX
Looked at it
Printed that fix and bought the O-rings. But I just wanted to confirm if anyone else had the same symtoms and had a fix. I do not plan to do the work myself and I am sure the cost to put the O-rings on will almost equal the cost of a PS pump swap.
Old 07-28-2002, 10:12 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
It would be a good idea to put new fluid in as well after emptying the tank and replacing the o-ring.
VK
Old 07-29-2002, 08:21 AM
SVX/NSX
Question So is it the O-rings??
I'm not really getting the answer I'm looking for here...So is it the consensus opinion of the both of you that this is the common O-ring problem? Because what I am trying to determine is if it is the o-ring problem, PS-Pump faliure, Steering Rack, etc.
Old 07-29-2002, 10:13 AM
vkykam's Avatar
It's just a little hard to diagnose it thru the ether...
It COULD be the pump, it COULD be the o-ring, it COULD be just old fluid.
If you already have the o-ring, it takes 15-20 minutes to find out and very little $$$ and effort if you do it yourself. If it fixes it, great, if it doesn't, maybe it's the pump. It's a quick and easy way to narrow down the problem.
You also didn't mention the colour/condition of the fluid or whether there's any leakage from anywhere, or if you're losing fluid.
VK
Old 07-29-2002, 10:48 AM
When I bought my SVX, it was hard to steer at slow speeds, the steering wheel surged when I turned it at very slow speeds, and there was some PS fluid that was leaking below the storage tank. The fluid was not very good either.
The O ring was just changed at the 10th Anniversary Meet, and it has worked great after that. I put in new fluid to fill the tank afterwards, and will change it again in a week or so. This is a very common problem with the SVX. Many people have gone to a dealer, and the tell them that they need a new PS pump ($450.00) and after it is replaced it still does the same thing. Others have asked on this forum, and have changed the O ring and have solved the problem, and have never had to repalace the pump.
Good luck and I hope this has helped you decide whtat to do. It is very easy to do it yourself, so try it, and see if it solves the problem.
Old 07-29-2002, 01:02 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Steering Problem (Lack of Boost)
I'd be willing to go out on a limb and say you just need to change the o-ring. If I were a little closer, I'd come over and do it for you, just to save you the money/headaches of taking it to a dealer. It is sooooooo simple to do that even the "mechanically challenged" could do it. I hate to see anyone pay dealer labor rates for such a simple fix, and one they'll probably balk at doing. Best o' luck.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-29-2002, 04:50 PM
The squealing noise is typical of a loose drive belt, especially if it does it when full lock is applied. Check it first.
