Old 06-26-2009, 12:31 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Wheel experts have a look!
Again, posting pictures of wheels that don't fit isn't really any help. Remember it is a 112x5 with a 23 offset 14x6 wheel. Nothing else is even close. They were made specifically for the car. Oh and spacers won't work beyond a 3mm spacer as the lugs aren't available longer.
Out of round is about $100 a wheel, cracked rims like I have are just going to crack again. Refinishing add $150 or so a wheel.
Old 06-26-2009, 01:11 PM
essveeexxee essveeexxee is offline
10 characters.
Old 06-26-2009, 01:19 PM
benebob's Avatar
Originally Posted by essveeexxee View Post
Last I heard you were talking about swapping a ford engine in it. Did you? If so what. If you kept the stock one what is it and what's the HP.
Swapping if it was dead as I bought it not running. It has a Ford Cologne 2.8 in it, hp is around 150.
Old 06-26-2009, 05:02 PM
benebob's Avatar
Any thoughts on these? (which I like but only the silver is availabe in a 5x112 (at least according to one ebay site but this site doesn't list 'em in that size). They would still stick out 9mm more than stock
http://www.esmwheels.com/Wheel_002.html
or these (which I hate BTW but fitment wouldn't be an issue)
http://www.discounttiredirect.com/di...r=5&wd=16&rw=7
or these (which I hate less a bit then the ones right above) They'd stick out at least 4mm than stock, more if I need to put a spacer to make up for the 8mm loss inner.
http://www.discounttiredirect.com/di...6&wd=16&rw=7.5
Old 06-26-2009, 05:14 PM
The ESM "Old Skool" wheels would suit the style, particularly in silver.
The other two are too modern for the age of the car.
You are right Ben. It is exceptionally difficult to get 14 x 6 x 5 x 112.
Old 06-26-2009, 05:50 PM
benebob's Avatar
You are right Ben. It is exceptionally difficult to get 14 x 6 x 5 x 120.
112 Joe, 112 and the stocks were for the 3rd and final time 14x7s with a 5x112 bolt pattern and a 23mm offset!. Again I want something that I can get more than a T/A single A rated H speed tire for too!
I wouldn't even put the silvers on a TR7 with the Tartan interior and they just emailed they don't make 'em with a 5x112 bolt pattern in black so they're out.
Old 06-26-2009, 05:59 PM
10 characters.
Old 06-26-2009, 06:51 PM
Originally Posted by benebob View Post
112 Joe, 112 and the stocks were for the 3rd and final time 14x7s with a 5x112 bolt pattern and a 23mm offset!. .
Sorry Ben. I meant 112. I'm numerically dyslexic at times.
Old 06-26-2009, 07:07 PM
benebob's Avatar
Figured as such. Why don't you just yank some off some poor saps TVR and send me some anyways!
Old 06-26-2009, 08:42 PM
wawazat??'s Avatar
Yeah, I'm still around
Ben,
Mid-late 90's Audi A4 and the VW Passat (B5 nomenclature-1998-2007 I believe) all use 5x112 BCP along with certain Mercedes models. Tirerack shows a lot of 16" wheels available when I selected a 1997 AudiA4 FWD and they typically provide specs including offset in their descriptions. Hope it helps
Down to none
Old 06-27-2009, 04:29 AM
benebob's Avatar
Originally Posted by wawazat?? View Post
Ben,
35-45mm offset. Ain't gonna work no matter how hard I try with spacers. Already been there and done that but thanks anyways Chad!
Old 06-28-2009, 05:51 PM
subeman90's Avatar
Soobologist
hahahahaahahahahaha chrome?!?! are you serious
can you get them in 20"?
15 OBW premium w/eyesight
Old 06-28-2009, 08:08 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
last one isn't too bad
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-28-2009, 10:16 PM
BoxerFanatic's Avatar
I would seriously consider some wheel spacers that change the bolt pattern. Those do not require longer studs, as the spacers use redundant studs, spaced on a different bolt circle. they basically bolt to the existing studs with short, open lug nuts, and then between the original studs, they have 5 more studs, either closer to, or further from the hub center, essentially adding offset requirement to the wheel, and changing the bolt pattern to something more common. Easier than changing the hubs and brakes...
At this link, it lists the H&R brand PCD adaptor options...http://www.performancealloys.com/all...s_adaptors.asp
In the audi section, it shows a 5x112 -> 5x100 adaptor that keeps the center bore lip at 57.1mm for hub-centric. If that is what your dimensions are, you could change over to 5x100 wheels, such as the Rota RB, or other Audi, VW fitment wheels.
With a 20mm spacer added to the hub, and a wheel with more positive offset, the RBs have +35mm offset, you end up with about 8 millimeters more net offset change... and add a quarter inch (6.35mm) for both inboard and outboard for the 7 inch wheel width, over the 6.5 inch wheel width you had before... and you roughly have 14.3mm, or a hair more than half an inch outward change in the outboard rim edge, compared to the 14x6.5, 23mm offset wheels.
I would go for 5x100, and put those Rota replicas of Panasport wheels on the car. I would also perhaps see if they come in a nice muted gold color on the spokes, with a machine polished rim edge... that would look nice with the tan interior of the car. I say that as a person who is NOT a fan of gold wheels on most other cars.
5x112 bolt pattern, pretty much anything you are going to find are going to be mercedes wheels, or as someone mentioned, very rare audi wheels. most current Audis have switched to VW's 5x100 et35 specification. Hardly anyone else uses that bolt pattern.
The ESM BBS-knockoff wheels you linked to don't look too bad... and from your pictures, look somewhat similar to what was on there before, with red painted cast mesh. I would go with silver or gold wheel centers, though.
the third option thick 5 spoke is too modern, and the thin tapered 5 spoke is FAR too modern.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
