  #61
Old 07-23-2009, 09:01 AM
Re: Back on the beat - Phast's turbo SVX gets some love
Originally Posted by Tim View Post
Dyno it in Jersey and you can have it in 1080P 25mbit/sec bluray quality video
Show off
Old 10-01-2009, 11:23 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
E85 and 15lbs of boost. It is rediculous. No knock and more power you could ever dream of. Slow burning so less tensile pressure than gasoline and cool at RBT. No need to build a motor for thousands of dollars with this kind of performance and tourqe.
~Phil
Old 10-01-2009, 01:27 PM
Phil, that's cool man.
Pun intended.
Phil, what all did you have to do to make the fuel system safe for or compatible for E85?
It should be worth my while converting for the supercharged one I have.
Old 10-01-2009, 08:17 PM
FriendlyTurkey FriendlyTurkey is offline
What size injectors are you on with the E85?
Old 10-04-2009, 10:14 AM
Phast SVX's Avatar
Pun intended.
Just replaced all the soft rubber lines with new alt fuel compatible and we will see. No problems and not the first time or first person. No where near as corrosive as methanol.
~Phil
Old 10-05-2009, 11:16 PM
You must be up there around 450=475+ BHP now I'd guess if you don't have any major restrictions in your system. I have a feeling with a good tune on E85 you aren't going to have any detonation issues. I'd suspect you'll have a long life at your current boost level.
Old 10-10-2009, 05:24 PM
Phast SVX's Avatar
Ya...nothing yet. For the most part you can make as much power as you have fuel. No detenation past LBT just less power.
Sorry for not answering your previous question. I have 2v7 flex fuel ECUTune software running 370CC redtop injectors, a walbro HP fuel pump, and a RRFPR running 6:1 for added flow.
~Phil
Old 10-11-2009, 08:37 AM
longassname's Avatar
Just some dude.
Yep, that's the way to do alcohol injection. He'll probably get more power too when I switch the current releases of stage 1 and 2 to the aggressive versions.
Pun intended.
Old 10-13-2009, 11:51 AM
If your base fuel pressure is 45psi, I get the following:
Base (psi) 45
Boost (psi) 15
FPR rate 6
Injector Rate (45psi) 370
Pump Head Under Boost (psi) 135
Injector Pressure Delta Under Boost (psi) 120
Injector Flow Under Boost (cc) 604.2074699
With a BSFC of 0.75 and HP of 450, it looks like you are on the bleeding edge of what your current injectors will support. What AFR and Duty Cycle are you seeing with your current setup?
Old 03-25-2010, 09:09 PM
Phast SVX's Avatar
This just in via network post. Phil's new license plate is SP00L1N
~Phil
Old 04-11-2010, 09:28 PM
Phast SVX's Avatar
I got to spar with a Viper today. He took off while i was behind him at a stop light and I stuck with him in first gear more or less.
Why is it that they will never do anything when you get next to them? I have no doubt a late model viper is much quicker, especially at anything other than a standstill, but its as though they do not want to find out! I would like to see how I line up at speed. He did give me a thumbs up, so i suppose I should take what I can get.
Car is still running great. stage 2 aggressive is really the icing on the cake when it comes to performance and stock drive-ability.
~Phil
Old 04-12-2010, 03:28 AM
We can't have street racing posts on here Phil, so I expect you were in a car park or somewhere, right?
And a more interesting test might be if you tried it on in heavy rain, I'd expect he might be too busy twirling the steering wheel to give you thumbs up as you pass.
