Old 12-22-2008, 11:17 PM
svxash's Avatar
svxash svxash is offline
Do I need hub centric rings?
I'm looking at summer wheels and I figure I will need new lug nuts but I don't know if I need hub centric rings.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 12-23-2008, 11:43 AM
immortal_suby's Avatar
Thread Killah
Re: Do I need hub centric rings?
yes you need them.
Locker Link
2015 BRZ Limited 6MT
Old 12-23-2008, 05:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
+1 to what Matt said
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-23-2008, 09:59 PM
svxash's Avatar
As far as the lugs go do I need the longer ones or should I use the short ones?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 12-23-2008, 10:14 PM
Lugs? Nuts or studs? Stock length studs should work fine with any wheel unless you're running some ungodly spacer. You will want to pick up a set of lug nuts though (12x1.25 thread, 19mm hex). The stockers won't fit into smaller holes, plus they look stupid on different wheels.
Old 12-23-2008, 10:18 PM
svxash's Avatar
Sorry,
I meant lug nuts. I wasn't sure if I needed the long ones or the short ones.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 12-23-2008, 10:19 PM
Anything should work, I just have a set of generic chrome ones for my STi wheels. I briefly entertained the thought of some fancy Gorilla spline drive ones, but they cost a wee bit more. ($135-ish)
Old 12-23-2008, 10:47 PM
svxash's Avatar
Where's the best place to get them?
Thanks
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 12-23-2008, 10:59 PM
I was working at a tire shop at the time, so I just grabbed a set and gave my manager $10. Depends what you want really. If you're just looking for something to do the job any tire shop should be able to help you out.
The spline drive tuner nuts are a bit nicer, and come in different colours if you prefer that. (chrome, black, red, blue...)
I'd say online is the easiest way to buy those. Try here maybe:
http://fastwrx.com/mcsplugnutse.html
And the super-fancy forged alloy nuts:
http://fastwrx.com/forallugnut.html
Note for those: HAND TOOLS ONLY, hand torque, all that good stuff. If anyone ever approaches them with an impact gun go after them with a hammer.
Old 12-25-2008, 01:47 PM
svxash's Avatar
What is the correct size of the hub centric rings?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 12-25-2008, 08:27 PM
It depends on the wheel. The ring has an inner and outter diameter. The inner should be 76.1 or 76.15 mm (to fit the SVX hub). The outter diameter will fit the wheel you select, so you'll need to get that spec from the wheel manufacturer.
Old 01-12-2009, 08:13 PM
svxash's Avatar
That seems big. I think the center bore of the wheels I bought are 73mm. Aren't most Subaru's 56.1mm
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 01-12-2009, 08:59 PM
That sounds right to me. Sorry, it's been quite a while since I checked the fitment chart I had at my old shop. If I had a caliper on me I would just go measure one of my summer wheels that's sitting in my bedroom...
Old 01-12-2009, 09:00 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
You absolutely need the hub centric rings for any aftermarket rim for the SVX or any other car. The hub centric rings "center" the wheel on the hub. Without them, the balance of the wheel / tire will be off - the wheel and tire could be balanced perfectly off the car (as is the norm now on a machine), but if the wheel is off - center even just a bit, you will get a vibration. Conventional wisdom used to be that the lug nuts would "center" the wheel to the hub, but that really is not precise enough for well balanced tires on the car.
And speaking of lug nuts, don't use just ANY lug nut!!! There are different lug nuts for different wheels, so match the nuts to your specific wheel - it's the angle of the taper that you need to be concerned with. The length of the lug nut itself should not matter assuming you have a deep enough socket to tighten it with .......
My two cents based on a bit of experience over the years...
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 01-17-2009, 03:43 PM
svxash's Avatar
Which style of lug nuts are better or is it just a matter of preference? It would seem like the allen style would be more prone to getting rusty vs. the spline drive.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
