#136
Re: TURBOs!?
Blah blah blah blah
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by TomsSVX; 10-21-2012 at 07:53 PM. |
#137
Re: TURBOs!?
Blah blah blah
#138
Re: TURBOs!?
What a mass debate
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#139
Re: TURBOs!?
:unamused:
#140
Re: TURBOs!?
As I mentioned to Tony and what the plot shows is it's still accelerating to the rev limiter and it's increasing in it's acceleration - which is stunning considering the effects of air resistance at 100 mph start really acting on the car etc. The stock cams are absolute rubbish for anything but a stock setup and should be upgraded as a major priority. The order or priority should be duration and lift, then buckets, valves, springs and then maybe changing the centrelines etc. Last edited by bazza; 11-03-2012 at 11:57 PM. |
#141
Re: TURBOs!?
The camshafts were not the only change that you did to this engine, over the first. You also changed the connector pipe that connects the two exhaust manifolds, to the turbine, from this, short type that the early kits use, Perrin used and you copied. You changed the connector pipes to, two longer, separate pipes, to the turbine, that Phill, Phast SVX used, I recommended, and you built for this engine. You don’t know what you have done that has caused any change. I’ll continue on the Camshaft thread in time, about you poor choice of cams. Harvey.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 11-04-2012 at 04:39 PM. Reason: Found the pict. |
#142
Re: TURBOs!?
Over the last few months I've noted that the people who've followed your advice over the years have NEVER produced one decent result to date. All your theory polluting these forums for 10 years and not one single decent result to show for it. How do you explain that? It's a disgrace really given people listen to you blindly. Your ego and arrogance is expected of course but if you check the timestamps - my version 3 headers were built well before you got on your high horse. The fact that you think I did something on your advice is embarrassing. Now I could prove this beyond a doubt but you'd still argue and claim to be the EG33 Guru which is funny given your terrible record to date. |
