Old 10-04-2008, 06:11 AM
legacyau legacyau is offline
Aussie high beam question
Can anyone tell what bulbs thay have in their high beam lights mine has H3 bulbs fitted and i'm thinking theyre not right as the high beam spread is really crap, my low beam is better than the high!
regards cam
Old 10-04-2008, 04:31 PM
Re: Aussie high beam question
They aren't brilliant are they.
I fitted 100 W high beams, with a 20 amp high relay. Not too bad at all, just only use them when moving, or the plug and wiring can get too hot.
Old 10-04-2008, 04:45 PM
AUSVX AUSVX is offline
Registered Loser
mine aren't doing too well either. I took out the little parking lights and I want use HIDs in place of parking lights but in place of the halogens if that makes sense. Do you know if the gauge of the parking light cable will be too thin to run HIDs in?
The idea was, you turn the light switch once and HIDs come on, flick it a second time and the JDM fogs come on :P and high beam can be just be standard high beams.
Sorry to go a bit off the subject cam
Jordan
Old 10-04-2008, 11:13 PM
Well the reason i was asking is that I put 100watt bulbs in and the lights are worse I was thinking that maybe i have the wrong type of bulb fitted as the yanks have a 9005 bulb fitted in theirs as far as i can see, the focal length seems to be wrong ?
cam
Old 10-05-2008, 04:10 AM
Cam, do your cars have the glass lamps, or are they the plastic type, same as the JDM ones and the US?
The reason I ask is this; H3 for the main beam is correct for the glass type.
What is listed in the manual for the other lamps [they way they put it is "Vehicle with headlight with beam angle gauge"] Inner: 9005/HB3
The Outer [dip] is listed as 9006/HB4
Headlight beams are good to very good on my glass UK headlights with standard 55W bulbs. I could NEVER get good light from any of the Japanese lamps. They are crap.
Old 10-05-2008, 08:32 AM
That is why so many of us have gone to the HID Kits. They are about $200 USD, but they are so much better than stock, they are worth it.
Old 10-05-2008, 04:31 PM
Registered Loser
Hey Ensteele, do you have HIDs installed? If so, did you cut out the old Halogen lens and fit HID lens with the cut off line?
I'm still trying to find all the info I need to do this and which lens to use.
Do any aussies have HIDs installed??
Jordan.
Old 10-05-2008, 05:41 PM
I don't know about the glass lenses, but the plastic JDM or USDM lenses work just fine. You put the lights into the same place your regular lights go in and the balest plugs into the light wire that is there. I will try to get a how to done. The lights are great. The ones I have are the 5,000 calvin and there are 6K, and 8K. The 5 are a nice bright white color and the fog lights look more yellow compared to them. I have two sets and I love them. I just have them in the low beams because of the projector lense. When I flash on the high beams, it is the same, but that wasn't the problem before. Just the low beams were bad.
Old 10-06-2008, 12:01 AM
Dessertrunner's Avatar
Cam,
You can fix the SVX lights so they work well as long as they are glass. Change the highs to 100 watt H3. as you have done. The most common mistake is to put them in upside down. You need to check the locators on the bulb.
Tony
Old 10-06-2008, 05:44 AM
thanks tony i'll check that out
