Old 10-01-2008, 12:06 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Water in trunk, but nothing's wet?
Well, I had a blowout on Rt.3 in Jersey today. Pulled over, went to the spare, and found the spare, tools, and jack underwater. I immediatly thought that it was leaking from the plugs I put on when I removed the wing, but the trunk liner, part of the trunk we normally use, and all my stuff in there, was not wet. Where the hell is this coming from?
Old 10-01-2008, 01:02 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Water in trunk, but nothing's wet?
Could be clogged sunroof drain or seals around the tailight. See this thread: http://www.subaru-svx.net/forum/show...unk+water+leak
Gene
Gene and Ben
Old 10-01-2008, 03:03 PM
Could be the drain that got moved in the trunk, but I would guess that it is the gaskets behind the tail lights. That is where it usually comes from.
Old 10-01-2008, 09:37 PM
Mensaf's Avatar
^I believe you're right. Was looking @ the tail light and I see condensation. bwb3, thanks for the links. I have the part numbers too now. Gonna go to Subaru tomorrow hopefully.
Old 10-01-2008, 09:52 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Yeah after washing my car the taillights would get a foggy condensation on the inside.... which bugged the crap out of me. I sealed the plastic up with silicone but noticed the foam that keeps water out of the trunk was old and hard-pressed. I cant imagine enough water gettin in thru the taillights to fill your spare tire area though....id check the weatherstripping around the trunk area it might be rolling off the back window down into the trunk.
Old 10-01-2008, 09:59 PM
That is where it is coming from.
Old 10-01-2008, 10:45 PM
Mensaf's Avatar
I can buy these gaskets seperatly, right?
Old 10-01-2008, 11:19 PM
Yes, they come for each light. It takes 2 for the center finish light.
Old 10-02-2008, 05:58 AM
Mensaf's Avatar
Hooray!! I you guys.
Old 10-02-2008, 11:02 PM
XT6Wagon XT6Wagon is offline
my lake SVX was from a sunroof drain somehow comming out in the trunk. It was way way way down in the side panel and you can't really see it till you know what you are looking for. Mine was on the driver side.
