Old 08-15-2008, 01:07 PM
92 30K mile SVX 92 30K mile SVX is offline
Tire Recommendations
Would appreciate suggestions for new rubber. More interested in a quite ride than performance. Any words of wisdom on allignment would also be appreciated.
After a year and a half, my little red SVX just turned over to 32,000 miles.
I live in North Palm Beach, FL.
Old 08-15-2008, 04:59 PM
processengr's Avatar
Re: Tire Recommendations
Hi,
One thing to keep in mind if you have an all wheel drive car, the tires must be very close in size.If you have mismatched size tires, you risk damaging drivetrain component$. Which means that a full road hazard warrenty won't be much help. If you have a blowout, punctured sidewall, or otherwise trash a tire once they are 50% worn,
1.You will have to find a tire that is the same size/brand with same wear
2. Buy new tire and have it shaved
3. Buy 4 new tires(what most do).
That said, I have had Toyo Proxes FX4, Falken Zeix 512(all season V rated) and FK452(summer only) Continental, and Kumho Ecsta MX (summer only), Nitto (snows) and Hankook Icebear (V rated snows) tires on our SVXs. The quietest were the Contis (H-rated).
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-16-2008, 11:14 AM
SVX_MY_BABY's Avatar
Match the edge profile of the OEM Proxes ie rounded rather than square. The suspension likes the tires move a bit more than the square edge allows which cause the square edges to wear prematurely.
32,000 miles! Maybe you should put it on blocks & store it then get another to drive.
Old 08-17-2008, 06:56 AM
Originally Posted by processengr View Post
Hi,
Thank you "processengr". I may try the Continentals.
92 30K mile SVX
Old 08-17-2008, 07:11 AM
Originally Posted by SVX_MY_BABY View Post
Match the edge profile of the OEM Proxes ie rounded rather than square. The suspension likes the tires move a bit move than the square edge allows which cause the square edges to wear prematurely.
SVX MY BABY, thanks for the suggestions. Mine is driven about 1,300 miles per year. I bought it from a close friend who drove it about 2,000 miles/Yr.... He replaced all A/C items. Replaced the timing chain, (before it had a chance to fail). Lots of things for which I have the records. The car began claret but he liked red and spent a fortune repainting it during the first year of ownership. (I have never seen a better paint job.)
One naging problem both he & I have had for a number of years, - - we thought it was some sort of "draw" on the battery. A series of higher & higher capacity batteries until I just recently was told that his mechanic had replaced a failed alternator with one 85 amps (instead of the 95, factory one). Found this when the 85 amp one failed me. I am hoping that this will solve the problem. (I have been somewhat suspecious of the security system, [ which neither of her 2 owners know how to use ].)
92 30K mile SVX
Old 08-17-2008, 10:03 PM
Nevin's Avatar
Nevin Nevin is offline
I have a set of Michelin Pilot Exalto A/S in the stock size 225/50R16. It's considered a high performance all season tire and I use them for my "winter" tires. The ride is amazing, and they also handle very well.
A VERY good tire, if you ask me. I work at a tire shop and I recommend these as often as I can.
Here's a link to them on tirerack. THey are currently priced at $130 each, which is a pretty good size considering the performance, ride, and the life you'll get out of them.
http://www.tirerack.com/tires/tires....t+Exalto+A%2FS
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-18-2008, 08:38 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Your tires are like mine, dead long before the tread. Falken Azenis might be good for you or Bridgestone RE-01a (stock on the STI). Good solid value tires that will net you about 10k-12k on them.
92 30K mile SVX
Old 08-19-2008, 09:50 PM
subarufamily subarufamily is offline
cooper xeon are the choice tires for mine as they work good in ALL( including snow) weather, ride quiet and have good tread wear. my opinion plus they are not as costly as most
William
Old 08-19-2008, 10:09 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
I used to work for a goodyear tire shop. My boss SWORE by Goodyear Assurance Tripple Treads. It's design pushes away the water. http://www.goodyear.ca/img/tt-intro.jpg
Dry 10
Wet 10
Snow 10
http://www.tirerack.com/tires/tires....nce+TripleTred
I'm just about positive it has an 80,000 mile wear out. It doesn't last that long but I think they'll garantee it.
My moms got it on her audi and it handles like a dream. Its got an agressive tread design and leaves a cool tracks in the snow.
Wait............. here
http://www.goodyeartires.com/goodyea...area=Passenger
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 08-20-2008, 08:14 AM
benebob's Avatar
I don't think I'd ever put an 80k wear out tire on a car that is driven less than 2k a year. At worst case you should replace the tires every 7 years. Recommended to replace at 5 years from manufacture date. In other words he'd be paying and throwing away tires that still have the nub on 'em.
Dry 10
Wet 10
Snow 10
Old 08-23-2008, 11:08 AM
Jnthn_Sctt Jnthn_Sctt is offline
Just my two cents
Had Pirelli P-Zero Nero's, (225 / 40 18") good all season tire and nice cruising, but don't think I'd buy them again. Price is a bit high and don't handle as well as I'd like.
Have Bridgestone Blizzak LM-22 (Stock 225 / 50 16")winter tires, great in the snow and not bad overall. A bit much for an all season, but I know people who do run them year round. Would buy them again unless Bridgestone comes out with something better.
Running GoodYear F1 all seasons (255 / 40 17") Was a toss up between all seasons and summers, but live in NY and wanted to be safer in the late fall and early spring months. (For Florida I would have definitely gone with the full blown summer tire.)
In the future will stick with either Bridgestone or GoodYear. Decision will be based mostly on price.
(Daily driver, 140K miles and still going strong)
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf.
Old 10-17-2009, 02:24 PM
92 30K mile SVX
The SVX has this problem and all of mine are the same. If they sit for more than 2 weeks or more without being driven, the battery will go dead. I either disconnect the battery, or put a battery tender on them. That is about the only way you can keep the batteries charged without driving them.
I would never shave tires, and would only replace them 4 at a time. Never replace only 2 at a time. Good luck on your search for tires.
Old 10-17-2009, 02:55 PM
svxash's Avatar
svxash svxash is offline
Are you staying with the stock wheels?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 10-17-2009, 03:20 PM
But be sure to check the dates on the actual replacement tires themselves. Just because you buy them new doesn't mean they are.
See this ABC News Special Report tire safety video. It is most important.
http://abcnews.go.com/Video/playerIndex?id=4826897
Old 10-17-2009, 03:43 PM
sunvalleyray sunvalleyray is offline
For what it's worth, Comsumer Reports rated Michelin Pilot Sport PS 2 as the best summer Ultimate high perforance tire in their last buying guide. In addition Car and Driver (Aug 09) used the Pilot Sport as their benchmark to measure all other tires against. BMW M3, Porsche 911, Boxster and Cayman, Corvette XR 1 and Cadillac CTS-V all come with the Pilot Sport.
I have Michelin Pilot Alpin PA 2 for my winter tires and love them. I also use Michelin tires on my Toyota Tundra, both winter and summer, and have run 85,000 miles on the summer tires!
Running Yokahama's now for summer tires and do not like them, seem noisy to me. I plan to upgrade next summer to the Pilot Sport but I am sure there are other great tires available. Be aware the Pilot Sport's are very expensive, somewhere around $200.00 per tire.
Good luck,
sunvalleyray
