Old 06-20-2008, 05:56 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Unhappy Require Harmonic Balancer for SVX (Down Under)
Hi guys,
My car is becoming a money pit. But I still love it.
I now require a Harmonic Balancer for the front of the engine, my current one is about to fail.
Could anyone help me find this part? I also will require a timing belt and crankshaft seal. Where should I go in the Sydney Hunter Valley region?
Still saving for my new transmission and now this happens!!
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 06-20-2008, 06:37 PM
AGREENTREEFROG's Avatar
AGREENTREEFROG AGREENTREEFROG is offline
TREEFROG
Re: Require Harmonic Balancer for SVX (Down Under)
Brady I can supply you with cam belt for 168 bucks - genuine
cam seals are 13.40 each and also crank seal is also 13.40
with regards to your harmonic balancer id suggest you ask Tony (desertrunner) as im sure he has a spare, new ones are 355 bucks from subaru
Regards Andy
Old 06-20-2008, 10:51 PM
BRADY's Avatar
SVX Addict
Thanks mate, will PM you about those bits.
OK. The Harmonic Balancer (or crank pulley) is broken. Here is pics I took with my phone.
Old 06-21-2008, 06:12 AM
AUSVX AUSVX is offline
Registered Loser
what was the sound coming from your engine bay before you took the pulley off?? high pitch or low, could you locate the sound at all.
Old 06-21-2008, 06:19 PM
BRADY's Avatar
SVX Addict
Hey mate,
The Pulley FELL off!!
For about a week or 2, the belts were "screaming", particularly when AC was on and when turning the steering wheel.
Mike
Old 06-22-2008, 09:03 PM
legacyau legacyau is offline
http://www.trademe.co.nz/Trade-Me-Mo...-161991958.htm
have a look at this one maybe
Old 06-22-2008, 09:52 PM
Originally Posted by BRADY View Post
Hey mate,
Mike
That the way they usually go. Did it damage the timing belt cover?
Old 06-23-2008, 01:49 AM
BRADY's Avatar
SVX Addict
Hi Harvey
It didn't really damage it, as it happened in my garage. A few small gouges in the tb cover.
That NZ one looks nice. It says it also fits leagcy, wrx etc. This was a question I was going to ask - are they interchangeable?
Old 06-24-2008, 07:26 AM
Hi Harvey
Yes they are as 2.2 and 2.5's, I know up to at least 99's. If you just want a cheap stock one, I'm sure you can find one off of a Liberty or whatever you call an Impreza over there...
Old 06-25-2008, 02:13 AM
BRADY's Avatar
SVX Addict
Thanks everyone. That is awesome help.
By the way, the Impreza is called an Impreza in Australia too. A Legacy is called a Liberty.
I believe all the other model names are the same. EXCEPT of course, for the ALCYONE SVX. I am not sure which market had that ALCYONE prefix? JDM? USA?
Old 07-03-2008, 08:54 AM
subbieatnz's Avatar
i fitted an alloy 1 to mine. it fitted well. i brought the combo with the crank, alt and powersteering pullys. the ps and alt where diff but the crank was perfect fit.
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 07-24-2008, 12:41 AM
BRADY's Avatar
SVX Addict
Hi SVXy people.
Just found some "Harmonic Balancers on ebay for WRX - does anyone know if they fit the SVX?? I have been led to believe that the pre 2000 WRX and Impreza ones fit......
http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=025
http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=019
Thanks
Old 07-24-2008, 04:59 AM
The SVX uses the same hamonic balencer as all the EJ series engines, so you can pick up one off a Legacy or Impreza (or those aluminum ones off EBay...though they will rub the t-belt cover a little....but will "wear in" after a little running ....
Old 07-29-2008, 12:15 AM
BRADY's Avatar
SVX Addict
Thanks! Tony had a spare and sent it to me - thank goodness!
Now, if Tony only had a spare transmission, I would be set!!
I am bamboozelled my the transmission problems - there must be a cheaper way than the $3,500 I am being quoted.
Mike
Old 07-29-2008, 06:23 AM
Mike
hi brady have you let your fingers do the walking? i'd ring around and get prices i was quoted about 2500 here in brisbane i'm sure you could fit another 4eat from a later liberty they arent that dear you just need a vtd version and you may need to change the tcu to suit failing that i'm sure the centre section of the gearbox is identical to the aussie ones maybe you could build one from a used one ?
cam
