Old 07-16-2008, 02:40 AM
Re: carbon fiber driveshaft
Originally Posted by TomsSVX View Post
a one piece driveshaft was made for a 5mt not that long ago. The angles are too intense for a one piece. It will create vibrations that will not only be an annoyance but it could potentially destroy your transmission ie: blow apart the rear portion of the trans... So, I would recommend against ANY 1 piece Drive shaft. Thats why i always use customized SVX shafts with new universals
Tomn
What is the source of the vibration? Lack of a dampener? No center bearing? Small diameter?
Old 07-16-2008, 01:58 PM
svxpert svxpert is offline
<<What is the source of the vibration? Lack of a dampener? No center bearing? Small diameter? >>
being one piece, the universal will be at a real angle to fit. that means alot of stress on it. it will wear uneven and eventually fail.
Old 07-16-2008, 05:39 PM
Good to know. As of today I'm no longer going this route. The shop is just not up to it. They refuse to make a 2 piece.
Old 08-06-2008, 01:18 PM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
Is the angle too extrem only for manual SVX's or for automatic too ?
Nightmare is the name of the car...
Old 08-06-2008, 09:13 PM
It's the same, just a slight difference in length.
Old 08-07-2008, 07:30 PM
SpoonChucker SpoonChucker is offline
I would have posted this earlier, but I don’t get on this site that often. I had an aluminum drive shaft made about three years ago. It has a slightly larger diameter (compared to stock) for strength reasons. This also meant that the heat shield had to be modified so that it wouldn’t rub (in addition to being a “one-piece”). For all of the reasons mentioned in this thread I put the stock driveshaft back on about two week after installing it. Vibrations were noticeable around 60-80 mph. It is lighter but I never weighed it. I never noticed much of a change in acceleration if any at all.
Old 08-07-2008, 07:32 PM
in order for the D/S to work it would need significantly larger U-joint which means a fully custom shaft and joints... also means BIG money. I have toyed with the idea of having my D/S shop make me one for my silver... but the stocker has been fine so when I need a beefier one I will have it made
