Old 02-11-2008, 12:16 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Lovely cars, Rebecca, and I'm pleased too they have found an owner that will care for them properly.
A question; are you saying the Claret had been doing 23 with standard gearbox, but after the 4.44 swap now gives only 19?
You would actually expect a drop, because the engine is now revving more for the same speed than it was before. However if much of your miles included highway, then for a long top gear run you should be in the 20-22 range, down the shops maybe 18. Maybe you are using the right foot a little more with the sporty gearbox ratios?
the poor gas mileage started about 2 months ago. My 4.44 swap was last May. With the 4.44 I got between 20 and 25 depending on city or highway.
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 02-11-2008, 12:35 PM
That's good to hear, in a way.
Sorry, I'm not smiling at your increased consumption, I'm merely happy that the 4.44 change alone did not bring things this far down in consumption.
You might not have seen it Rebecca, but there is a recent thread about poor consumption and possible causes.
In no specific order, here are a number of possible causes:
Bad MAF
Bad O2 sensors [bad or dirty]
TPS adjustment not right.
Clutches starting to slip in gearbox.
Dirty injectors.
Clogged airfilter.
Brake pistons holding the brakes on after application because rubber seals damaged and pistons can't retract freely.
Like any troubleshooting list, approach this by checking the easy and cheap things first. These would be things like a dirty air filter or fuel filter. Or checking the TPS.
If your miles are high enough, say 80K plus, then it would be prudent anyway to strip off the calipers and do a refurb on the seals, ensuring the pistons are smooth and shiny for retraction while doing the job.
O2 or MAF or brakes would be my "Order of Suspicious Merit"
Old 02-11-2008, 12:51 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Really??
Actually it is very reasonable to assume that you would get fewer miles per gallon with the 4.44 swap if you continue your usual driving habits. To maintain the same speeds that you are used to driving, your engine will have to turn at higher rpms---generally meaning higher fuel consumption.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-11-2008, 01:20 PM
Lee
Yeah, that's correct Lee, I did actually mention that in an earlier post.
Running the maths on it an acceptable touring mileage of 28 with the original 4EAT final drive will now deliver:
28/4.44 *3.54 = 22 mpg.
It's likely that the tendency of the 4EAT to seek higher gears when changing up [based on the internal mapping] will have the gearbox running at optimal torque all the while with the lower final drive, which will mitigate the consumption loss of gearing drop a little bit.
I'm just musing that Rebecca may have another factor adding to the increased consumption.
Old 02-11-2008, 03:31 PM
SVXyGirl's Avatar
Bad MAF
Dirty injectors.
Clogged airfilter.
Thanks. I replaced the fuel and air filters recently. I'm thinking 02 sensors. I'll probably replace them when I get home....and a semi nice day
I was surprised that my gas mileage was that good. I'm not a fan of the high rpms though.
Rebecca
Past SVXs:
Old 02-11-2008, 04:58 PM
You could be very right with the O2s.
I know what you mean about the high revs, but Tom swears by the 4.44, mostly because they don't break easily.
Ratios
I did a spreadsheet comparison between ratios so that I could judge what ratio was best for the supercharged engine. The 4.11 came out on top, but only because the 4.44 was so low.
For sheer grunt the 4.44 must be the best value. I figure a 4.44 combined with a supercharger engine would be something of a drag car for hauling ass, and probably sore on tyres. I'll probably build a special gearbox for the supercharged car this summer and I'm leaning towards a 4.11 for touring comfort.
I had the 4.11 box on my Legacy TT [270hp] and it really moved very well. The only thing was it seemed to only hold 1 and 2 for milliseconds.
Old 02-11-2008, 10:32 PM
Hondasucks's Avatar
Subaru Technician
I cleaned the injectors on my 92, and replaced the fuel filter, and my mileage dropped to like 15 on the following tank, then went back up to 19. Next in line are spark plugs, as far as tune-up stuff goes. Then all it really needs is cam seals, timing belt, and valve cover gaskets.
1986 VW Jetta
Old 02-12-2008, 09:49 AM
SVXyGirl's Avatar
In the past year I have replaced everything basically cept for the O2 sensors. The MAF was replaced about 2 years ago.
So I'm guessing those O2 sensors need to be done
I'll be home sometime tomorrow and maybe this weekend I can take care of that.
Rebecca
Past SVXs:
Old 02-13-2008, 09:50 AM
NapaBavarian's Avatar
Good morning!
Nice A collector, are you building a garage soon? Too bad all the cars are up north and back east
.Karl.
Old 02-13-2008, 10:27 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
Congrats on the new additions to your family (turns green with jealousy).
Still in love with my Subie
