Old 01-13-2008, 07:44 PM
Speedklix's Avatar
Locker Link Solution
congrats on getting the tranny in.
should have helicoiled/tapped for starter first, but you may be able to still do it. Just get the trans jack under there and slide the trans back on the studs just enough to tap the hole. use a magnet to mitigate the amount of metal shavings getting down in there (not good for bearings or seals)....
-edit-
and as for the axle issue... the ring on the stub needs to be positioned like open end down, it jams in the splines. rotate half a rotation when/if it stops moving while you continue to push in
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 01-13-2008, 08:01 PM
Originally Posted by sicksubie View Post
Tranny is in, slave cylinder is on, starter is.... not on. Do I have to drill for the lower mounting bolt?
Ouch.
Some things are better done before you re-install the trand.
Look in my locker under SOV13T's car for some helpful hints.
http://www.subaru-svx.net/photos/use...svxfiles|41147
Old 01-14-2008, 02:56 PM
svxpert svxpert is offline
on the 2nd picture on the first page, are those two rubber bushings the studs go through replacable? has anyone done that? mine are broke. thanks
Old 01-14-2008, 03:09 PM
Yes they are replaceable, but its not a job that everyone can do.
If you are comfortable changing exhaust systems, for example then you can most likely do the job.
Old 01-14-2008, 03:31 PM
here is the pic of the two bushings that i need to replace. anyone know the part number i need for them? anyone using aftermarket ones? thanks
Old 01-14-2008, 07:31 PM
Earthworm sells some that are better than stock.
Old 01-14-2008, 08:39 PM
this is what they look like. i have an extra set available. Maybe as payment for that master cylinder and a maybe a pedal box??
Old 01-15-2008, 12:19 AM
<<this is what they look like. i have an extra set available. Maybe as payment for that master cylinder and a maybe a pedal box??>>
yeah, that will work. pm me your schedule where you'll be this week and your phone number and we'll meet up. thanks
Old 01-15-2008, 09:20 AM
sicksubie's Avatar
Toms kit came this morning.... Wont have time though to do anything with it for a couple days....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-15-2008, 12:23 PM
sicksubie's Avatar
Front axles are a creating a problem now......
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-15-2008, 01:55 PM
sicksubie's Avatar
The axle with the toothed ring is the stock STi axle and the other is a SVX axle
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-15-2008, 03:28 PM
no dice. The axles seals on the hub are different diameters. You are going to need to use the stock SVX axles. Sorry man
Old 01-15-2008, 04:03 PM
sicksubie's Avatar
OK,,, but will they plug into the 6 spd as they are?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-15-2008, 04:51 PM
sicksubie's Avatar
Trans end of the front axles
STi one is the one closest
Sti one on the right
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-15-2008, 05:27 PM
Yeah, we had to do this to Gest24's trans too. You need to pop out the side plates from the transmission one at a time, switch the seals with ones from an SVX automatic(should order new ones) and then reinstall the plates to their original position. These should be done one side at a time to ensure you do not upset the gear's position
