Old 09-27-2007, 01:05 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Nitrogen in tires in place of Air
Its a pretty worth while mod, check your area and see
who is offering it. I know Costco offers it.
But nitrogen in place of air stays the same pressure forever
(or as long as you dont get a puncture in your tire)
so your mpg, tire wear and tire life are all improved.
Also keeps the carcass drier with less moisture inside which
is an improvement.
I just did it on a new set of Falken and SC430 wheels we have
here Im going to put on our silver car for a while.
Should cost about $50 to do all 4, but its only catching on and
more shops are offering it.
Im even thinking about buying the machine so I can offer it to
our customers.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-27-2007, 01:33 PM
So much for the autocross crowd, who are always pumping up and bleeding off their pressures.
Much more complete information HERE
Old 09-27-2007, 01:36 PM
RSVX RSVX is offline
Network Design Administrator
Bah, overrated.
I really only saw the need for it on the Aircraft I used to fix for the USAF.
Life is a game. Play to win.
Old 09-27-2007, 01:55 PM
Most tires are filled with compressed air, which when dry consists of about 78 percent nitrogen, 21 percent oxygen, and 1 percent other gases by volume. Water vapor (humidity) can make up as much as 5 percent of the volume of air under worst-case conditions.
Filling your tires with nitrogen mainly does two things: it eliminates moisture, and it replaces skinny oxygen molecules with fat nitrogen molecules, reducing the rate at which compressed gas diffuses through porous tire walls. That means, theoretically at least, that a tire filled with nitrogen retains optimal pressure longer, leading to more uniform tire wear and better gas mileage. The commonly quoted figure is that tires inflated to 32 psi get 3 percent better mileage than at 24 psi.
I don't know of any scientific tests showing that nitrogen-filled tires stayed inflated longer than average under normal conditions.
As for moisture, changes in humidity affect tire performance two ways. First, the density of humid air fluctuates more with temperature than that of dry air, so removing humidity can keep your tire pressure more consistent, especially when the temperature climbs over 100 degrees Fahrenheit. That may be a legitimate concern in Formula One racing, but it's not much of an issue if you're just tooling around town.
Humidity can also be a factor in wheel maintenance — since pure nitrogen doesn't have moisture in it, supposedly your wheels won't rust as quickly. But this should not be an issue for us since we have aluminum alloys
Another claim I've seen is that since nitrogen is slightly lighter than air, you'll save weight and get better performance. However, we're talking about a weight difference of less than 4 percent of the gas in the tire — in other words, a difference of less than an ounce for most vehicles.
A possibly more realistic benefit is that nitrogen is largely inert chemically at low (i.e., normal) temperatures, so it won't attack the rubber in your tires like oxygen does.
If I bought my tires at Costco and had them installed, nitrogen is free. But since since Costco doesn't sell Toyo Proxes, and I check my tires weekly, I'll use that $40.00 or so I'm saving towards something more fun.
Old 09-27-2007, 02:07 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
Originally Posted by RSVX View Post
Bah, overrated.
My car is a jet fighter.
I heard about this awhile ago. nitrogen is way better than oxygen, so long as its practical
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 09-27-2007, 02:16 PM
for $40-50 I think its worth it
just for the simple fact the pressure stays Constant
from day 1 ... Most people dont check their tires enough
anyway, even Im guilty of it and Im in the business. For
me its one less thing to worry about, and in gas alone in
the first yr Im sure Id save the $ I spent. Just for the peace
of mind.
I think its a good idea for anyone who wants worry about less
maintance or has a few cars to worry about too.
Esp for anyone who never checks their tire pressure but every
few months it would be ideally for. Also the fact your tires at
a constant pressure would only help with tire wear too.
To each their own, but Im sure someone will find it useful on
the site other then me.
And if you do buy your tires at Costco, correct they do it for
you automatically. The price is included in their installation.
There is a Discount Tire in Scottsdale and San Diego that both
offer it as an option when you buy their tires for a small added cost
too.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-27-2007, 02:18 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
40-50? Most of the places around here put it in for "free" with new tire purchase! Only real advantage for those who take care of their ride is that it doesn't introduce water into the tire area so it helps with rot.
of mind.
too.
Old 09-27-2007, 02:30 PM
yeah, and Im in the tire business and can tell you 80% of car
owners dont put tire maintance on the top of their to do list
If they do it for free, thats great but dont kid yourself
they factor it into their tire prices and or service.
If they can make $ offering it as alternative, good for
them too Its not like they are forcing anyone to buy it.
Even Costco charges $4 per tire for any refills later on if
you get a leak in the tire. Theres no reason they should give
it away since the machines cost close to $4k or more.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-27-2007, 02:57 PM
immortal_suby's Avatar
Thread Killah
or you can just keep adding compressed air to your tires every month until the small percentage of oxygen leaks out and they are naturally nitrogen filled
Locker Link
2015 BRZ Limited 6MT
Old 09-27-2007, 03:48 PM
my brother has an 07 STi
Since he has a TPMS on my car that gives both pressure and temp, he can tell you even around town at 80F, tires easitly get to 100F. ON the freeway they go over it easily. IN Tucson, at 100F, my tires are seeing 135+F.
I know that during the last 4 weeks, he has adjusted my tires at least 2 times a week due to the changes in temp. adding or removing air every time. If you live in Bora Bora where the weather is th same everyday, fine. but for anyplace that has temp flucuations, N2 is not a bad idea. Just put a TPMS in your car like I did and you'll see the range of temp and pressure changes on a daily basis.
Lighter then air was never brought up as a selling point.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-27-2007, 04:13 PM
wawazat??'s Avatar
Yeah, I'm still around
Any gas volume will expand and contract with temperature and subsequently change psig in the tire (PV=nRT). As such I don't see the point to pay extra to "Nitroinize" as they call it around here . As John stated, air is mainly comprised of nitrogen most ambient conditions preclude 5% water vapor in compressed air systems. I also routinely rotate my tires on all the fleet and with the SVX I am constantly checking and bleeding/inflating the tires due to autocross action.
But, everyone has their choice as to what they will pay for.
Todd
Down to none
Old 09-27-2007, 04:46 PM
Todd
Well this wasnt an attack on you or how you maintane your car...
If it doesnt work for you, no need to comment in my opinion.
all it started out was and should remain as is "useful information"
to anyone looking for a Mod for their car that it may apply to.
Lets leave it at that cool ..thanks.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-27-2007, 09:04 PM
When I worked with medical supplies, I used to fill my tires with oxygen.
For no other reason then the fact that I always had tanks in my car.
Old 09-28-2007, 05:46 AM
wombat wombat is offline
I run nitrogen in all of my tires, truck, car, trailers race cars. For me, the biggest advantage is that you do not get the rise in PSI with nitrogen as much as you do with compressed air. Admitedly, it's probably the absence of moisture that accounts for that but when you find something that works.....but when you are able to anticipate a cold tire set at 24psi heating to a hot pressure of 30psi, you have a better chance of running more consistantly. I know it doesn't matter for the street as much but if the compressor that you are getting air for your tires from has a drier, that should be good enough for the street IMO....
A large bottle of nitrogen goes for @ $250.00 here and a nitrogen regulator runs around the same so, for $500.00, we have a system we bring to the track and use for tires of course as well as air tools..(no moisture, and no noisy compressors at the track!!). Refills arent that much but the initial investment is a killer.
Old 09-28-2007, 06:22 AM
wawazat??'s Avatar
No attack interpreted on my part Dayle, merely my view which is different than your view on the subject. I didn't intend to remove the thread and as long as any post meets the rules of the SVXWN it can stay so I won't be removing my own post. It's a discussion board not an agreement board You posted an idea and I posted an idea.
Todd
Down to none
