Old 04-02-2007, 11:30 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
4.44.......what else
So im gonna be getting 4.44's in a month or two. What else should I do while the tranny is out? I'm just trying to decided what I should hit while im under there and have alot of time devoted to the car.
Dustin
-Dustin
Old 04-02-2007, 11:47 PM
nextse7en's Avatar
Graphic Artist
Rear main seal (maybe) 02 sensors (maybe) exhaust manifold to pipe seals.
Rear diff bushings. Trans cooler flush.
I'd also adjust the brake band on the new (if its used) transmission back to factory torque specs, and replace duty sol. c with a new one while the tranny is out of the car. Will probably save you money in the long run.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 04-03-2007, 03:28 PM
trans internal filter change is a huge thing to do. Rear diff bushing, harder trans mount, replace soft lines running from trans to hardlines under the driver's side head.... Dunno what else...
tom
Old 04-03-2007, 03:36 PM
Speedklix's Avatar
Locker Link Solution
-o rings in the fittings on the steering rack.
....-change power steering fluid ofcourse
-reseal oil seperator on back of engine/replace if cracked/plastic
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 04-03-2007, 04:22 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Front axles, ball joints,trans mount rear seal on trans and engine clean firewall area mine was covered with axle grease pain in the a$$ but looks better now
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 04-05-2007, 07:30 PM
longassname's Avatar
Just some dude.
having it sent to me and getting it built before you put it in would be a good idea if you have the coin
Old 04-06-2007, 04:42 PM
odepaj's Avatar
Killer of threads
I wanted that 3.90 tranny from you but dont have that kind of cash
dustin
-Dustin
Old 04-07-2007, 03:17 AM
Duckie Duckie is offline
Send a message via AIM to Duckie
When it comes to tranny trust me when you get what you pay for. Replacing to subpar tranny 50k or less miles down the road makes His tranny look mighty advertising...not to mention cheap. I have been waiting for a tranny like this and to tell you the truth I was quoted twice as much from some other places I trust. Andrew tech had my money until Lan made this; now once the money exists its in his pocket and not theirs.
Old 04-07-2007, 03:57 PM
odepaj's Avatar
Killer of threads
I havent heard bad things about the 4.44 geared trannys yet but if the one im getting goes out, im just gonna go to an mt.
Dustin
-Dustin
