Old 02-23-2007, 06:10 PM
processengr's Avatar
Question How to replace rear diff bushings
Hi all,
Had a problem replacing the rear differential bushings in our 92 SVX.
I bought new bushings from 1st Subaru. read all posts regarding installation, sounded easy, brought to Local shop who torched out old bushings, could not get new bushings in.
Ended up frying new bushings trying to heat the surrounding area.
Help! Ordered new bushings. Does anyone have a how to on this? Shop
had the standard C-clamp like tool for bushing press. Does the rear
end need to be dropped?
TIA!
gordon
Old 02-23-2007, 06:35 PM
Welcome to the site. I am not aware of a how to on this, but I will do some searching for you.
Old 02-23-2007, 06:37 PM
SVXBart SVXBart is offline
i sugest you to contact SVXFiles or TOMSsvx,as they both curently did it.
Bart
Old 02-23-2007, 10:03 PM
Long bolt... couple big washers... corresponding nut for the bolt. LOTS of Grease After that it is self explanitory with an impact gun
Old 02-23-2007, 10:19 PM
When I replaced Harry's bushings, I found out it is MUCH better to make two cuts with a sazall, about 1/2" apart, and to peal out the sliver of metal, than it is to make one cut and try to peal it out.
Old 02-23-2007, 10:28 PM
he said he already got them out... now its just a matter of gettin the new ones in...
Old 02-24-2007, 07:04 AM
Please use a press, sazall, dremell or ANYTHING but a tourch, so close to the gas tank!
As to installing the ones that I hand made, I used a dead blow hammer against a flat metal bar, and lots of lube.
Old 02-25-2007, 06:55 AM
Smile
Thanks everyone for quick response! I'm guessing the mounting studs come out with a jamb nut?
I may try to remove the torched bushings and install the replacements myself. This was my original intention, but it has been cold in Conn.!
Gordon
Old 02-25-2007, 08:22 AM
Gordon
Did the shop remove the rear differential before they tried to tourch the bushings?
The two studs stay in the rear diff and are out of the way.?
Are the bushings out yet?
Here is a picture of what it should look like before you try to reinstall the bushings.
Old 02-25-2007, 11:01 AM
No, they left the differential in. Does the mount need to be dropped?
Old 02-25-2007, 01:46 PM
I would drop the rear first.
Unhook the driveshaft, four nuts.
Six bolts, two nuts and two axles for the rear.
Once the rear is out carefully sazall out the two bushings outer sleeves using two cuts about 1/2" apart so that you can peel out the bushing.
Then as Young Tom says use a big a$$ bolt nut and washers, lots of grease to press in the new bushings.
Or combine that with the cro-magnon method of a metal plate and a four pound dead blow hammer.
Can you do it without dropping the rear.
Could be, but you would spend much more time and effort, using laser scalpels and or Dremels, and stuff that most shops do not have.
Old 06-01-2007, 09:00 PM
We used no grease when replacing mine. We were actually able to press out one of the bushings. The other we cut.
Old 03-02-2009, 12:07 PM
RoughSilver92 RoughSilver92 is offline
Re: How to replace rear diff bushings
Bringing this back from the dead, but Advanced Auto Parts rents a ball joint pulling tool that works great for this. Just find the right size pieces and use the c clamp provided. I had to remove the muffler and drop the sway bar to be able to get the socket on the c clamp, but other than that nothing to it. I went this route as opposed to cutting them out because I wanted to save the metal pieces to fill with window weld.
Old 03-02-2009, 01:05 PM
kwren's Avatar
kwren kwren is offline
depends on the torch but could possible have damaged the area the bushings fit in??
Keith
