Old 02-05-2007, 09:07 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Shift lock unit + gear change for "POWER" switch
ok - so since I brought up the "POWER" mode switch thread - is seems to be gathering momentum.
Here is another question - I have managed to get hold of 2 shift lock units
(JDM = 88083PA000 & USA = 88083PA010)
Initially I thought that they may hold the key to the mysterious variations between models in the "POWER" switch area - but blow me down with a feather when I checked my NZ new model (1995) I found that my car does not even have one of these modules??? By the way it is the same PCB but different types of components builds.
Both these units were located near the hand-brake area under the center console?
It seems funny that NZ does not have this black box - or maybe it is located somewhere else?.
By the way in the JDM that has both "POWER" mode switch & gear interlock tswitch - the blanking plates to locates these switches in my NZ model are part of the main surround - THEY ARE NOT A PUSH OUT BLANKING PIECES.
So if the mod to fit "POWER" switch is required them it may mean drilling out plate or finding a JDM plate.
Also in 2 other non-JDM units the screw boss mounting for both switches were there - so just remember to also get the screws!!.
Old 02-05-2007, 09:38 PM
I doubt that the "Shift Lock" box controls the power mode. It's purpose is to prevent movement of the shift lever until the car is turned on. It also prevents the starting of the car unless it is in P or N.
Old 02-05-2007, 10:50 PM
Thanks Dave you are correct.
I have a JDM SVX with this button and it is very useful to not have it concealed. I use it often when shifting/pushing the car back a little in the garage.
Old 02-06-2007, 11:12 AM
SURTEESS's Avatar
Cool thanks for clearing that one up
Having never tried to start my car in Neutral - but will see what will happen tonight (or maybe nothing will happen?).
Old 02-10-2007, 08:06 PM
With the JDM SVX, what does the power button do? I have been searching to see what it does.
Old 02-10-2007, 09:51 PM
When the power button is activated, the shift points are raised and as a result the speed in each intermediate which is reached, before a shift occurs.
Old 02-10-2007, 11:55 PM
Thanks
I finally found a couple of threads on the subject.
