Old 11-20-2006, 10:08 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Ecu Speed Pin
Installing my speed meter. I found a Ecu pin diagram. The speed meter needs a "speed signal wire" will Vehicle speed sensor 2 (B60, 11) work. Looks like the correct 5v signal, just checking.
http://www.subaru-svx.net/forum/atta...6&d=1058575037
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-21-2006, 07:34 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Yes. That's the one.
It's a 5 volt square wave, the frequency of which is proportional to your speed. Four cycles per revolution of the sensor IIRC.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 11-21-2006, 07:38 AM
Speedklix's Avatar
Locker Link Solution
Sounds accurate.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-21-2006, 11:46 PM
Dessertrunner's Avatar
The speed sender on the gear box works by pulling the voltage supplied low not by supply a wave form from 0 to 5V as was thought before. If you mesure the voltage on the ECU it has power. DOn't know if that helps.
Tony
