Wrx 5 speed cluch. Which one should I run?
Looks like I should be getting a WRX trany this week end.
My question to you 5 speeders out there is what clutch should I run? I see all kinds of different ones on ebay. Stage 1-5, racing clutchs. I just want one that will work well and not brake the bank. My car has some basic mods on it. See my soundomain link for the full run down.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
On my 6MT I just used the stock exedy set up. If I go froce fed in the future I'd prob. swap out but as it sits, the SVX's HP output is comperable to an WRX so there shouldn't be any issues.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
I'm still running the stock WRX clutch. It won't slip unless you foolishly heat it up.
O, I thought some one said to use a stage 2 or something. So I should be ok with a stock replacement clutch.
If yours didn't come with a clutch (like mine) then go with stock or some form of stage 2. Remember that as clutch performance increases, ease of use decreases.
Sure. Also, don't forget about a flywheel. Do you already have something in mind for that?
you should be fine with that clutch if you're not drag racing or attempting a burnout.
more importantly... have the flywheel machined! a stock wrx one is fine.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
Yes, I got a stock wrx flywheel on the way and a legacy mt drive shaft too.
I just need to find a mt starter and a master clutch. I can't wait to drive my svx again.
I may be picking up a pedal box and clutch master... You interested??
Tom |
If its a WRX clutch master, then yes. I already got a wrx peddle box a wrx slave clutch and I should have a wrx trany on sunday.
Also how backed up are you on making the 5 speed parts. I got all of the pieces ready.
i am in Philly almost always so I am leaps and bounds away from my shop. I will let u know if I cam but I doubt it
Tom |
Its not something I would need done right away. The trany that I'm getting is going to need some work. If you can doing it some time in the next couple months that would be ok.
oh ok... I need to try and get about 7 or 8 X-members done but I just don't have the time or the cores. I have only done 7 or 8 of them to date and I think 3 or 4 sent me cores back... Anyway I will see what I can do
Tom |
Thread Tools | |
Display Modes | |
