Old 07-11-2006, 08:08 PM
mikeytown2 mikeytown2 is offline
Sway Bar End Links
I took my car to midas to have the alignment done and they said my front passenger Front Swaybar End has some play in it. Can i get some help for what part it is and whats the part # is so i can order a new one. They want $178 + Labor to do it.
1) FRONT WHEEL BEARING 2) KNUCKLE 3) LOWER CONTROL ARM
4) LOWER BALL JOINT 5) STRUT 6) STRUT MOUNT
7) COIL SPRING 8) STABILIZER BAR 9) BUSHINGS
10) BRACKET 11) LATERAL ROD 12) LEVER
13) LINK 14) CROSSMEMBER
01 $622.26 Sub frame assy(front)
02 $269.71 Lower arm sub assembly right hand
03 $269.71 Lower arm sub assembly left hand
04 $63.12 Ball joint complete
05 $1.93 Flg bolt socket m12
06 $1.55 Self lock nut
07 $4.39 Flange bolt arm fm14
08 $80.04 Stabilizer front d18
09 $33.34 Lever stab front
10 $6.27 Bush stab in front 18
11 $5.35 Clamp stab front
12 $0.80 Flg bolt
13 $2.91 Self lock nut
14 $46.24 Link complete stab front
15 $1.37 Bolt&wash assembly
16 $8.15 Stpr flt bush front
17 $10.96 Spt sub frame front
18 $32.99 Spt sub frame rear
19 $3.25 Flg bolt sub fr
20 $1.71 Flg bolt(stopper)m12
21 $2.49 Bolt stud m10
22 $30.85 Performance rod
23 $1.04 Flange bolt
Or do i just need to tighten a bolt? How can i check this to make sure i don't waste my money.
I plan on replacing it myself then taking it somewhere else to have the alignment done.
many thanks
-mike
Old 07-11-2006, 08:15 PM
My guess is they are talking about 13 on the top diagram, 14 on the bottom.
If you pull a wheel you can readily inspect these links. There is a joint on both ends, check for play. You should be able to twist it, but not shake it.
Another possability is that the bushings are shot. They are 9 top/ 10 bottom. Chike did a how to on replacing them with aftermarket.
Old 07-11-2006, 09:51 PM
Upon inspection the end link is a little bent near the top where it mounts to the strut. I had to take a straight edge to it to see the bend. Is this supposed to be like this or should the end link be straight as an arrow? As for midas saying there is play in it... thats BS.
Here is the link to Chiketkd Prothane Bushings Install
http://www.subaru-svx.net/forum/show...232#post282232
Old 07-12-2006, 11:38 AM
It's supposed to be straight. I would remove the top nut and inspect the hole the link goes through. Mine was elongated and would cause free play. All we did was cut a chunk of washer to fill the gap. Been like that ever since
Old 07-12-2006, 06:51 PM
I inspected the other side and that also has a very slight bend in it near the top of the end link. both sides have no play, so i think midas was looking to make a buck off of me. Oh well.
NW alignment shops
http://www.subaru-svx.net/forum/show...alignment+shop
Old 07-12-2006, 07:27 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I replaced mine with links from a late model Cougar (the small one.) The studs point the same direction but since I put them on almost a year ago they haven't been a problem. My cost was $16ea so figure less than $30ea retail.
Plus, they're shiny aluminum! Oooooooo
If I recall correctly, the originals had a slight tweak on one end.
Old 04-06-2007, 09:57 AM
Brian's Avatar
Brian Brian is offline
Question
I need to have my links replaced. Thanks for this thread, Mike, because I was also looking to see which part was what the mechanic referred to as a "rear sway bar link".
Beav, Did you have to modify the Cougar links at all, or were they a perfect fit as is? That seems hard to believe. And now that another 3/4 year has passed, are they still holding up?
Old 04-06-2007, 06:42 PM
ShiuludeSVX's Avatar
Cool
I've been looking for a solution for these parts for some time now.
Can you locker some pic's of the links that you used, and what year Cougar did you get them from?
Oh. Nice collection of pic's in there. I really like the Blower pic.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 07-24-2008, 03:31 PM
SuberNatural SuberNatural is offline
Re: Sway Bar End Links
Bump. I need new links and this would be nice to know
Old 07-25-2008, 03:56 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
This might help a little.
http://www.subaru-svx.net/forum/showthread.php?p=557474
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
