Old 06-24-2006, 09:35 AM
Dengue's Avatar
Dengue Dengue is offline
My kitten can woop your kitten
Send a message via AIM to Dengue Send a message via Yahoo to Dengue
fuel pump replacement
I think my fuel pump may be dead, I know there is an access port under the back seat, but when I looked up the part on advance auto parts it said something about having to drop the tank, is that correct? or can I just change it from the back seat?
Skip
'95 SVX L - Laguna blue 126,000+ miles
'89 XT - some sort of sun bleached blue
'00 Hyundai Sonata- charcoal gray (hers)
Old 06-24-2006, 12:54 PM
Old Fogey
There is a special tool, "Replacer"(42911PA000) listed in the book to remove the cap, as well as documented cautions re: venting fuel system, etc etc, but this is doable in the car. I'm sure our members have improvised a way to do it without the tool. I've thought about doing this to clean/replace the fuel sender(s) and straighten out my fuel gauge.
Glenn
Old 06-24-2006, 10:00 PM
it can and has been done inside the car
Old 06-24-2006, 10:12 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
if its any thing like the saab one i just did you have to tap on the ring it is screwed on and needs to be taped off i used a small hammer and a philips screw driver
- John
Old 06-25-2006, 10:08 AM
Dengue's Avatar
thanks alot, I'm hoping that the fuel pump isn't the problem, but, my diagnostic skills are pretty weak, I'll just for fun throw the symptoms out and see what comes back....
the check engine light has been on and off sporatically for about a month now, and the car is running a bit rough, sometimes, it doesn't start as easily as usual and a few days ago, it wouldn't start for quite a while, and then when it finally did in ran like it wasn't getting enough fuel, and then ultimately, it died. 2 days later, I started it again, and it sputtered like it was short of fuel again, then suddenly, it smoothed out and started running, still a little rough, and the check engine light is still on. even before the check engine light came on, I noticed that frequently when I started the car, I could smell gasoline in the cabin, and it smells like bad gasoline.
the only other thing I can think of is that it seems like this started after the car sat for about 2 months without being started. (I had surgery and couldn't really move around to get to the car)
hopin' for some insight!
Skip
Old 06-25-2006, 01:05 PM
Be sure to unplug it and then vent the tank before you start to take the plate under the back seat off.
Old 06-25-2006, 01:24 PM
intelisevil's Avatar
<<<Alcyone
A good place to start would be to read the codes in the ECU to see why that pesky check engine light (CEL) keeps coming on. There's some info on how to do this in our How-to Documents:
http://subaru-svx.net/photos/user.php?How-To|14264
Good Luck,
Dan
Old 06-26-2006, 05:59 AM
dcarrb dcarrb is offline
I agree that checking the codes is the place to start. I've never heard of a fuel pump gradually, progressively failing. Maybe they do, but in my own experience ('86 Suby GL), when the pump goes, there's but one symptom: Things become quiet mighty quickly and you find yourself coasting to a stop on the shoulder.
dcb
Old 06-26-2006, 04:13 PM
Dengue's Avatar
Good Luck,
Dan
yeah, I already got that how-to from svx-iw, but, step 2 is a bit tough, in that I don't really know what blue wire I am looking for. My car has has an aftermarket alarm, that was there when I got the car, and there is quite a bit of wiring there. I feel like a bit of a goob now, cause I have no idea what I am doing. If someone could make a copy of that picture with little arrows pointing to the correct wires and whatnot, it would be VERY helpful for the slow people like myself.
Skip
Old 06-28-2006, 05:26 PM
Dengue's Avatar
ok, so I figured it out, got the codes, I got 21 (probably not related to my current issue) and 56 (probably the cause of my issue) so, I'm hoping that it is simply a disconnected or damaged hose, but, where would I find this hose?
Skip
Old 06-28-2006, 05:28 PM
Actually error code 21 IS the problem. That's the engine temperature sensor.
I had that fail and I had a hard time trying to start the car. It would start but with low idle and if I touched the gas it would stall. Imagine starting an engine with manual choke that was turned off.
Old 06-28-2006, 07:29 PM
Dengue's Avatar
okey dokey... and is this something I can pick up at my local autozone, or am I gonna spend some time/money on this one?
Skip
Old 06-28-2006, 10:28 PM
order it from subaruparts.com and it will take 5 minutes to install, no lie
Old 06-29-2006, 05:54 AM
Skip
Not to dis Subaruparts.com, but O'Reilly Auto Parts had the Subaru part number cross-referenced in their system, and I think I paid about fifteen bucks; you'll pay half that in shipping alone from the former. The same probably goes for Autozone.
dcb
Old 06-29-2006, 06:12 PM
Dengue's Avatar
could I get that part number please?
Skip
