Old 06-13-2006, 04:21 PM
r85rx7
how many Catalytic Converters are there
how many Catalytic Converters are there on a 92. well my question is is the Y-pipe a Catalytic Converter? thanks aaron
Old 06-13-2006, 04:37 PM
triumph1902's Avatar
triumph1902 triumph1902 is offline
Yes it is.
________________________
92 Teal - Work in progress
Old 06-13-2006, 06:58 PM
r85rx7
thanks for the reply. the reason i asked is because i had my y-pipe replaces today and i didnt know if it was a cat so i wasnt sure if i was overcharged. thanks
Old 06-13-2006, 08:55 PM
intelisevil's Avatar
<<<Alcyone
If you had the work done by Subaru, you probably were . . .
Dan
Old 06-13-2006, 09:30 PM
Sr240sx's Avatar
Sr240sx Sr240sx is offline
DON'T SAY THAT... I need to get my mousebelts fixed by subie...
Old 06-13-2006, 11:48 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
There are 3 catalytic converters. The first 2 are right after the headers and are actually pre cats, and the main cat is also your Y pipe.
Old 11-21-2013, 10:47 PM
kjoyes kjoyes is offline
Re: how many Catalytic Converters are there
Hey there are 6 part numbers for the pre-cats left and right so that make 3 different sets. could someone explain the difference between the them.
what one would be better for performance
44107PA240 SVX
1995-1997 Exhaust, Converters FRONT PIPE (with CAT) RIGHT passengers side FOR 1995-1997 SVX (WITH NON-CAL NON-CANADIAN SPECS)
44107PA250 SVX
1995-1997 Exhaust, Converters FRONT PIPE (with CAT) LEFT drivers side FOR 1995-1997 SVX (WITH CAL SPECS ONLY)
44107PA320 SVX
1995-1997 Exhaust, Converters FRONT PIPE (with CAT) RIGHT passengers side FOR 1995-1997 SVX (WITH CANADIAN SPECS ONLY)
44107PA260 SVX
1995-1997 Exhaust, Converters FRONT PIPE (with CAT) RIGHT passengers side FOR 1995-1997 SVX (NON CAL, NON CANADIAN SPECS)
44107PA270 SVX
44107PA330 SVX
1995-1997 Exhaust, Converters FRONT PIPE (with CAT) LEFT drivers side FOR 1995-1997 SVX (WITH CANADIAN SPECS ONLY)
