Old 06-11-2006, 02:07 PM
AutoTchr AutoTchr is offline
2.5 Legacy Outback
Camshaft timing gears on a 2.5 DOHC.
Can these be removed without the subaru special tool? The bolts are very tight and any more force will break the pully.
note: these are composite pullies and I don't want to use any sort of a clamp or risk breaking one.
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
Old 06-11-2006, 04:11 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
ohhh yea i pulled mine off a few times on my old 2.5 legacy... you can clamp them with a chain vice grips it works pefect if your worried about it hurting it just wrap some electircal tape around it first
- John
Old 06-11-2006, 04:42 PM
Thanks but........my 1/2 Ingrasol Rand won't loosen these. I used the old timing belt, clamped it, and a breaker bar w/cheater bar. I leaned on it very hard and it would not break free. any more force is sure to break the pully. I must have an abnormally tight bolt huh? Can't use heat....composite pully.
I even went as far as to look in the service literature to see if this was a left handed bolt which wouldn't make any sense anyway.
Depending on the availability of the special tool, I may try your advice anyway. Pullies for those should be a dime a dozen......
Old 06-11-2006, 04:46 PM
Wait a minute.....How do you fit a chain clamp between gears? The clearance is too close! You must be talking about a single ohc
Old 06-11-2006, 05:37 PM
Suby Fan's Avatar
ohhh damn you got a doc! that sucks the fact that your half inch couldnt take it off is a little concerning... the subaru tool wont help. the gears are some what cheep new i think like 50 bucks or something so i would try to heat it... and go from there... why do you need to take it off any way? oh and make (if its on the drivers side) you get the one for the right trannsmition that you have they have diffrent pickup points on the cam sensor
- John
Old 06-11-2006, 10:01 PM
Cam seals leak. Ya the 1/2 inch impact does nothing. If I am very carefull with the heat it might work to heat it without damage.
I wonder if a previous tech used loc-tight? If so heat would do the trick. I can assure you these are tight. I knew I was in trouble when my IR didnt work. Maybe a student turned down the regulator on the air hose? I will check that twm. good night!
Old 06-11-2006, 10:12 PM
intelisevil's Avatar
<<<Alcyone
Darn kids . . .
Dan
Old 06-11-2006, 10:15 PM
Originally Posted by intelisevil
Darn kids . . .
Dan
I've said that more than once.................
Old 06-12-2006, 01:16 PM
got it. I pulled out all the stops. Cranked the regulator all the way up, oiled the gun, heated the bolt and the bolt came out. It seems that a previous tech or back yard mech cross threaded the bolt into the cam. The alignment pin for the cam pully was drove into the cam and chipped part of alignment groove in the cam. There is obvious damage to the bolt and cam.
I found a new pully and bolt for 25 bucks, so the only thing I am out was labor.
I think I can put it back together and make it work after I clean up the threads in the cam.
Old 06-12-2006, 03:51 PM
Suby Fan's Avatar
ahhh is there no better sound then the impact gun finaly spining free you know the WOOOOP after dadadadadada... but i suppose if it was striped you didnt get to hear that... i just have one question... HOW DO YOU STRIP A BOLT THAT IS LIKE 1/2 WIDE??? if you ever find out who did that beat them over the head while yelling HAND TIGHTEN FIRST ITS NOT A SCREW ITS A BOLT... sorry i really hate taking off striped bolts at work because when you do you have to fix some one elces mistake
- John
Old 06-12-2006, 07:37 PM
I know it. I lost a lot of time on that one because I had to chase parts. The other three came right off no prob.
