Old 05-31-2006, 07:49 PM
michael's Avatar
michael michael is offline
What Potholes ???
stainless steel brake lines & brake fluid
I'm in the market for both of the above. I have settled upon Dayle's brake lines and ATE Super Blue. Does anyone have some proven testimonials on these or better+cheaper stuff? Not lesser quality cheaper, only less expensive and not homemade! Thanks-Mike
Wanted: Steering Wheel
Old 05-31-2006, 07:54 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Check that the fitting installed on the lines match up exactly with the stock SVX mounting points (I'm talking about the attachment points on the strut housings, not at the caliber and hardline). I know the SS line kits from RaceConcepts do (at least the ones I bought for the front and back brakes did). As far as fluid goes, I think many of us are using the Valvoline Synth fluid with no issues.
Make sure to thoroughly bleed your entire system when you change out the lines.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-31-2006, 07:59 PM
michael's Avatar
What Potholes ???
I'm not on good terms with raceconcepts as of yet will Dayle's match up ok?
Old 05-31-2006, 08:17 PM
I like using the ATE Super Blue. I interchange it with the ATE Gold once a year. That way I can always tell when I have completely changed my fluid.
I am also using the Goodridge S/S lines from Precision brakes, the slotted/dimpled rotors from RaceConcepts and Akebono Pro-ACT ceramic pads all around.
Old 05-31-2006, 08:31 PM
michael's Avatar
What Potholes ???
How were Precision brakes to deal with? I have been getting screwed alot lately. Do you have a link? The goodgidge lines have zinc plated fittings correct? How are they holding up to the weather? How much were they. Did you have to buy different clips for the strut mount.
Old 05-31-2006, 08:50 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I bought mine on e-bay from irotors. They cost me $125 and they are very good. I tried buying from other places and the prices were ridiculous.
Old 05-31-2006, 09:01 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Got mine from irotors as well. Good quality and fit perfectly.
As far as fluid goes, unless you really work the breaks hard DOT 3 will suffice. I tend to burn up DOT 3 and on previous cars even vapor locked my brakes a few times.....boiled the break fluid which causes it to expand and lock the brakes.
Anyway, if you're like me then the higher DOT ratings would be the best way to go. By far DOT 5.1 is the top of the line. The military used to use DOT 4 silicone synthetic fluid but had too many problems with moisture contamination. Whatever you decide, stay away from any fluids containing silicone.
Here's a link that will give you some good info on brake fluid:
http://www.synlube.com/brake.htm
