Old 05-29-2006, 03:39 PM
dromano's Avatar
dromano dromano is offline
Originally Posted by Suby Fan
and lets not forget that using a actual impact wrench is always the best method as long as its 3/8
What's wrong with using a 1/2 impact wrench? Would it work to put a 3/8 adapter on a 1/2 impact wrench?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 05-29-2006, 04:05 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
too much torque most of the time
- John
Old 05-29-2006, 04:36 PM
dromano's Avatar
So, you could turn the pressure down to reduce the torque, sound reasonable?
Old 05-29-2006, 05:59 PM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
i find the easiest way to do this is to hold a breaker bar on the bolt, and have a friend crank the engine for the shortest period of time possible, if not put a screwdriver, crowbar, or any thing else that would do the same thing in the access panel on the top of the transmission, the same hole where you would take the torque converter bolts off from and use the flexplate to hold the motor.
Old 05-29-2006, 08:44 PM
Suby Fan's Avatar
well to be honest with you they are like 18mm solid bolts so you could hit at it all you want with a 3/4 inch impact... but its the bolting it back on that concerns me
- John
Old 05-29-2006, 10:23 PM
davew833 davew833 is offline
Put an 18mm socket on an 18" to 24" breaker bar, wedge the end of the breaker bar under something solid (I used the emissions canister bracket on the passenger side) and "bump" the starter briefly to turn the engine. Works like a charm! (works for Acura Legends, too)
davew833@yahoo.com
Former 6-time SVX owner
Old 05-30-2006, 10:09 AM
AutoTchr AutoTchr is offline
Smile The Right Way....
Torqueing the crankshaft bolt is the bigger issue. You will have to keep the engine from turning from under the car at the flexplate. I would not use the chain or strap wrench as it will tend to separate the inertia ring from the hub. This will cause the premature failure of the dampener. Have a friend help and use a torque wrench and tighten to spec.
PS. I think that the reason so many of us do experience dampener failure is the overtightening of the drive belts. When you reinstall them tighten them enough to work without slipping, and stop.
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
