Fuel pump power grounding out?
I'm having a major problem right now. Can't get the fuel pump to run. I tried disconnecting the modulator and the resistor and grounding the yellow wire from the resistor. Still no deal. But when I remove all my grounds, and when they are connected, my blue power wire to the fuel pump reads zero ohms to ground. Seem like a short. I have no idea where this could have occured. Anyone have any ideas.
Thanks Chuck D.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Problem Found
I found that the auxilliary air power line electrical connector, which is also powered by the line that goes to the fuel pump, was cracked and must have been grounding. Now I just need to find a new connector. In the mean time, I'm going to try to get the fuel pump back up and running without the modulator.
Still no fuel pump
fixed grounding problem. Still no fuel pump. Time to install a Walbro.
Well I opened up the gas tank. What a mess. I think I am just going to purchase the entire tank and assembly rather than deal with all of this crap. Any suggestions as to who has best OEM prices? I usually purchase from subaruparts.com, but I heard there was another.
thanks
thanks man.
Thread Tools | |
Display Modes | |
