Old 04-13-2006, 09:17 AM
Changes to the hubs...
We made some changes to the hubs on the racer.
Can you see what's different??
The new ones are on the left...
So we can in turn add these...
So our 275's will fit
ps, Bill(svxride) I need to talk to you, if you don't have my cell, call Ben tonight, I'll be down there...
Old 04-13-2006, 09:42 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Dave,
Which SCCA class will you an Ben be competing in this year? Street Mod or are you still going to be in EP?
2006 Steel Gray WRX TR (sold)
Old 04-13-2006, 10:56 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Would something like this work to help achieve our 55mm offset for rims?
If it does then that would open up a lot of options.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 04-13-2006, 11:20 AM
thundering02's Avatar
Giong back to the beaters...
Steve
that is going the other direction.....that leads to shallower or just more out in this case....we need deeper
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 04-13-2006, 01:01 PM
sicksubie's Avatar
What exactly are you holding and where exactly did you get it. I know that it is a spacer but what kind exactly? I have been thinking about getting some spacers for a mustang and putting them on my SVX cuz they both have the same bolt pattern. I'm just not sure how to figure out what wheels will fit then. How are you going to fit 275's in the wheel well and what wheel are you mounting them on?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 04-13-2006, 09:36 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Dave,
This looks a bit like what we used to do with VW Beetles years back (yeah, I'm old ). Only we used backward lug nuts on the "inside" of the wheel to push out the wheel the width of the nut. No solid spacer needed ....
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 04-13-2006, 09:38 PM
Chike,
We're in EP this year...
The spacer is a 1" spacer from Sardeson Racing, they do have different thicknesses available. To use one that thick, we had to find longer studs. The studs we found came from England.
The 275's are going onto our stock wheels, and in order to make them fit, we had to trim about 2" away from the fender. Eventually we hope to make up some wide fiberglass fenders.
Old 04-14-2006, 06:23 AM
newsvx's Avatar
That car will certainly corner much better with the wider stance!! Let us know how it works and if you think it puts too much additional stress on the wheel bearings.
Hope to see you and Ben at Reading!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 04-14-2006, 08:52 AM
Chiketkd's Avatar
Originally Posted by Hocrest
Chike,
Sounds good Dave. Definitely do what your budget will allow for suspesnion mods as the wider stance will effectively 'soften' your spring rates.
Old 04-14-2006, 12:21 PM
sicksubie's Avatar
Explain what you mean by "softer spring rates"
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 04-14-2006, 12:41 PM
Think "lever effect". The contact patch on the ground is further away from the strut and therefore has more leverage.
Old 04-14-2006, 12:47 PM
Chiketkd's Avatar
Correct. As the track is wider at each axle, forces acting on each wheel will be able to exert a greater force (through increased leverage) on the strut and springs. This is why when searching for aftermarket wheels for an SVX, it's typically best to go with one that has an offset of +48 or higher (OE is +55). Lower offsets can be used but with detrimental effects - increased brake dive, effectively softer suspension, etc.
Old 04-14-2006, 12:51 PM
sicksubie's Avatar
oh, makes sense. Does this mean that I should go higher than I was planning (250lb front 225lb rear) if I were to get these and also how would that work with my current wheels (18x7.5 +48 offset with 225/40/18's)?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-07-2006, 05:59 PM
We finally ran with the 275's mounted. They really fill up the wheel well and make the car stick to the track so much better. Still a little bit of spin on take off and it could still be pushed hard and slide on tight turns.
I can't wait till the 12"ers get fitted
and I know two of the wheels are on backwards...
Old 08-07-2006, 06:01 PM
Still can't tell how large the tires are from those pics.
