Old 04-24-2006, 12:53 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Originally Posted by Earthworm
You need 20 washers total...not 16
Thanks David, I missed that when I ordered mine the first time. I guess the second time too
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 07-04-2006, 03:49 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
Originally Posted by Myetball
In case anyone is interested, RockAuto sells a Corteco valve cover set with grommets for $58.79 + s/h. I've been ordering stuff from them and the Corteco stuff is high quality and fits perfectly.
If your grommets are hard as rock as mine were it's almost $40 + s/h to get them from Subaruparts.com. Add the cost of the other gaskets and the Corteco set is way cheaper.
Has anyone else used this kit? Is it as good as the oem gaskets? $30 cheaper than subaruparts.com seems like a good deal.
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 07-05-2006, 05:07 AM
svx_commuter's Avatar
Originally Posted by SVXMAN2001
chiketd, that pic of the exposed camshafts is beautiful! Great write up, so good i may just attempt it on my own! Oh is there a special grease that should be applied when reinstalling the new seals (rubber gaskets essentially right?)
I coated the entire gasket with silicon grease before installing to help reduce the oxdiation of the rubber, rubber will oxidize in air over time. I'll let you know if they last any longer.
I had to loosen the engine mounts and slide the engine sideways with a floor jack to get the valve covers out. I could not get enough room to slide it out.
It is not possible to torque some of the valve cover bolts when the engine is in the SVX.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-05-2006, 08:12 PM
immortal_suby's Avatar
Thread Killah
I had to raise the engine slightly also on one of my svx's to remove the driver side valve cover. The other svx I got it out without moving anything. I guess it is due to a small engine alignment/mount problem or maybe worn mounts?
Locker Link
2015 BRZ Limited 6MT
Old 07-05-2006, 08:22 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
I doubt anyone else has tried very many non-eom parts. For some reason most folks believe SVX's are some mystical special car that will only run on oem parts and dual flux capacitors. I rebuild engines on a regular basis and would run Corteco gaskets/seals in any engine. For those with less experience, sticking with oem provides a sense of safety and security.
In Korea the word for money is toni (spelling may be off) but as we used to say while chasing juicy girls "it's all about the toni!"
Old 07-19-2006, 06:35 PM
Merz's Avatar
I ordered the Corteco valve cover gasket set, and all it came with is the main gasket for each side, and 10 grommets total. Shouldnt it have come with the smaller gaskets for around where the coils go? and dont i need more than 10 grommets?
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 07-20-2006, 09:56 AM
You need a total of 20 grommets (10 per side) and 6 gaskets (3 per side)
Old 07-20-2006, 12:42 PM
Merz's Avatar
Thats lame. Now i need to order the other 4 gaskets and 10 more grommets.
So as a warning to everyone else, the Corteco valve cover gasket set only comes with 2 gaskets and 10 grommets total. Seemed like a good deal for $60. Now i know why.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 07-20-2006, 01:13 PM
Call them back and tell them what's missing from their shipment
Old 08-16-2006, 02:12 PM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
update...
i decided to go out on a limb and order from rock auto...
when the package arrived, it was just like the post earlier... 2 outer gaskets, and 10 grommets...
i called customer service, they said they'd call corteco (company that supposedly manufactures the gaskets)
i got a call back, corteco subcontracts ANOTHER company to manufacture
these gaskets (i couldnt get the name of that manufacturer)
also, corteco couldnt explain why they consider 2 of 6 gaskets and 10 of 20 grommets a full set, but that is in fact THEIR full set... they will look into pulling it off their website, but they have no plans of offering a REAL full set
all is being returned, no hassle of course..
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 08-16-2006, 07:41 PM
stallion stallion is offline
Ah... thanks for the update.
Old 08-16-2006, 07:56 PM
Merz's Avatar
Angry Another update
I installed the corteco gaskets and ordered what was missing from subaruparts.com. ended up costing a lot more than it should.
The worst part is that my valve covers are still leaking, maybe worse than before. I had a lot of small leaks before, mostly from the inner gaskets and around the grommets. Now i have a bad leak around the outer gaskets, which are the corteco ones. Im pretty sure these gaskets are the reason for the leak. they seemed thinner than the subaru ones, and im positive that i installed them correctly. I am extrememly frustrated right now because i spent hours changing them, and now have to do it again, and pay more money for the oem gaskets.
I went to the bar lastnight and when i came out, there was about a 12 inch puddle under my car. I was so mad, i wanted to drive the car into a tree, but i was afraid i would get a duii. I really just want to sell the car right now, if anyone is interested?????
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 08-17-2006, 09:56 AM
Tighten the bolts just a little more. Mine leaked after changing as well. A little tighten and it's dry.
Old 08-17-2006, 11:06 AM
Merz's Avatar
I will try that thanks.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 09-04-2006, 02:14 PM
Merz's Avatar
Well i tightened the bolts, and it still leaks. So i am going to order the oem outer gaskets and replace them again. Shouldnt take as long this time, because i know how to do it now. I think i'll use some rtv this time also.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
