Old 03-30-2006, 02:04 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
i dont take offense at all. I was looking at prices at for all seals, rings, and bearings it looks to be about $1000. Buying an engine with over 100k on it seems to be almost 1000 shipped so Im just weighing my options. Id feel alot more content with a fresh engine.
[SIGPIC][/SIGPIC]
Old 03-30-2006, 02:06 PM
but who would rebuild the engine?? it will rake more than just parts including getting the block/heads milled. glaze broken... etc
Old 03-30-2006, 02:27 PM
jman050's Avatar
Its a Classic!
im sure Id have to pay big money to get it rebuilt because I dont know anyone with the ability to do so in a timely manner. I might be able to chug through it slowly over the summer. The only real issue is that I dont need the car at all as a dd from may to the end of august. But after august It would be a huge struggle if anything did happen, and Id like to have a fresh car by then.
I appreciate this input. Criticism is always good so i know what im getting into or avoiding a rock and a hard place.
Tom- why would the heads need to be milled?
[SIGPIC][/SIGPIC]
Old 03-30-2006, 03:01 PM
anytime you seperate the heads from the engine it is a good idea to get them milled to prevent premature HG failure
Old 03-30-2006, 03:10 PM
jman050's Avatar
Its a Classic!
By getting the glaze broken are you referring to splitting the block to expose the crank?
Sorry for all the questions, im just trying to evaluate this project
thanks
[SIGPIC][/SIGPIC]
Old 03-30-2006, 03:14 PM
no i mean honing the cylinder walls. if they are in good shape then all you need is a honing. if they are bad(gouged(sp?)) then you will need to scrap the block or sleeve it.
Old 03-30-2006, 03:22 PM
jman050's Avatar
Its a Classic!
oh ok. I was just planning on having to have it honed. If the cylinder walls were badly damaged wouldnt I be losing noticeable compression?
Does splitting the block require any specialty tools?
[SIGPIC][/SIGPIC]
Old 03-30-2006, 03:47 PM
yeah a steady hand and long ass stats.(for pulling the piston pin clips)
Old 03-30-2006, 03:59 PM
jman050's Avatar
Its a Classic!
Im thinking it would not be a bad idea to buy a blown engine (excluding block damage or crank damage) and mess around with it, possibly rebuilt it and replace it.
How much would a blown svx engine run? assuming i could find one
[SIGPIC][/SIGPIC]
Old 03-30-2006, 04:14 PM
dunno prob 200-300. Ill sell u mine when I destroy it with a 165 hp shot of N20...hahaha
Old 03-30-2006, 04:39 PM
jman050's Avatar
Its a Classic!
Do you plan on making it off the line or just blowing ur differentials...but never the less sounds like a fun ride
[SIGPIC][/SIGPIC]
Old 03-30-2006, 04:43 PM
the 6 speed will handle it no problems... its the rest of the parts I worry about
Old 03-30-2006, 07:48 PM
jman050's Avatar
Its a Classic!
Are there any machine shops in NJ or eastern PA that have experience with Boxer engines?
And would it be a good idea to mill the block to for the same reason you mill the heads?
[SIGPIC][/SIGPIC]
Old 03-31-2006, 05:55 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I'll sell you mine as soon as I find one to replace it with.
Old 03-31-2006, 06:19 AM
PatrickB's Avatar
PatrickB PatrickB is offline
Send a message via AIM to PatrickB
Originally Posted by Electrophil
Unless you plan on replacing your tranny with the police special platinum edition, I wouldn't go there.
its not power that causes the 4eat to go in svxi its heat.
err read that up there then i saw where you said a 5mt. the 5mt failed due to power... and the stock motor has more power(torque) then a 5mt can handle imo.
