Old 03-29-2006, 02:54 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Getting engine ready for 100 shot
My engine currently has 194k miles on it. It had a sticky lifter that was resolved with MMO and it has an oil leak that needs to be fixed. Id like to install a 100 shot this summer. With an engine with these kind of miles what would you gurus recommend be done to the engine to make it safe to run nitrous and stay running for many more miles?
Should I replace the headgasket?
replace piston rings and hone the bores?
[SIGPIC][/SIGPIC]
Old 03-29-2006, 03:58 PM
don't use a 100 shot... 75dry has been the safetly limit for most without reducing timing. If you are going wet... 100 shot should be ok but make sure the engine is in good running condition
Old 03-29-2006, 04:22 PM
jman050's Avatar
Its a Classic!
I was planning on a wet shot. I know these engines have been known to go 250k+ but what areas should I look to replace just to make sure it lasts for many more miles. What usually goes on these engines first?
[SIGPIC][/SIGPIC]
Old 03-29-2006, 04:49 PM
If you want your motor to last longer, do not put nitrous in it
Old 03-29-2006, 05:13 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Unless you plan on replacing your tranny with the police special platinum edition, I wouldn't go there.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
jman050's Avatar
Its a Classic!
i was kinda hoping to offset the decrease in life from nitrous by replacing the parts that see the most wear from age. But im not sure if i should reconsider.
[SIGPIC][/SIGPIC]
What usually goes on these engines first? The transmission!
Robert
Old 03-29-2006, 06:37 PM
jman050's Avatar
Its a Classic!
If im not mistaken its more of a reason of heat rather than power. With a shift kit and tranny cooler ive heard that they can hold power quite well.
[SIGPIC][/SIGPIC]
Old 03-29-2006, 08:05 PM
No, that's right. It is heat. But if you throw 450 lb/ft of torque through that TC... well.. You know. It just won't be pretty after a few times.
Throw a 5mt in there first.
Robert
Old 03-29-2006, 09:07 PM
jman050's Avatar
Its a Classic!
financially and time wise a 5spd isnt really an option. And with a 100 shot an svx shouldnt put out much more that 350tq. And due to drivetrain shock and the fact that modded wrx have alot of transmission trouble id think that a 5spd would wear just as fast with nitrous.
I also know SVX files has a 4eat SCed car so i would think that vouches for the strength
[SIGPIC][/SIGPIC]
Old 03-29-2006, 10:18 PM
AvPPoW AvPPoW is offline
It's not a stock transmission, it's a 4.44 out of a newer outback
Old 03-30-2006, 03:17 AM
Which is actually weaker than the SVX 4eat... Listen, the trans is the least of your worries. The stock trans will hold it no problem but it's the motor you need to worry about. Nitrous in good working order is just more horsepower when you want it. The thing is, it will hasten the demise of your engine due to simple breakdown of parts. Extra Tq will cause extra stress on things like rod bearings which will wear out much quicker if the hp is increased be it nitrous or FI. It's simple, if you need your car as a daily driver and want to keep the engine ticking as long as possible, do not use nitrous
Old 03-30-2006, 10:30 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
If the engine has 194K, then the chance of running it on nitrous and keeping it running for many more miles is not terribly good? I say ride her till she f*cks you, or don't ride her at all. Motor swaps are easy. Don't waste money by putting it into a motor that you plan to beat on anyway. Start saving for a better, lower mile motor. You can get a good used motor for about the cost of new nitrous system. I ran a 75 to 125 dry shot for about 18 months. I settled on a 105 shot and used it sparingly. I only used about 10-12 bottles during that time and never saw any ill-effects. Of course, the next time could have been the last time. Start with 75 and don't gas off the line. Using it on the freeway is a blast. Its fun to be side by side with someone at about 65 and then just punch it and leave them like they were standing still. Make sure you choose your spots though, because the car will need a bit more time/distance to slow down. Try not to endanger other drivers. A brake upgrade would be a good idea. Also, an exhaust upgrade can yield huge results when you're squeezing. Good luck.
Stephen
Old 03-30-2006, 01:52 PM
jman050's Avatar
Its a Classic!
I may just save my money and buy a used motor if the current one blows. I know the blocks on these motors must be split to reach the main bearings, does this require a special tool?
I was considering doing a fresh rebuild of all seals, head gaskets, rod and main bearings, piston rings, and maybe having the rods shotpeened.
[SIGPIC][/SIGPIC]
Old 03-30-2006, 01:54 PM
not to be a dick... but do you know what that will take to do?? Do you know how much parts alone will cost?? Might make u reconsider
