Old 03-14-2006, 12:37 AM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
tranny question!....
hey guys... i'm finally getting worried enough 'bout my transmission to post a question... i searched the forum and didnt see anything directly relating... so..
when my wheels are spinning on snow or ice... sometimes i get a whiney noise for just a second...
-at first i figured i just melted my way down to pavement and chirped my tires... (getting out of a plowed in parking spot) but could it really be that simple??
-i can only think of it coming from more of the passenger side... (help narrow it down at all?)
-it DOES seem more common when one side(drivers side)of my car is on dry pavement and the other is on a slippery surface.. (tire chirping? or car
crying??)
-i want to change any and all fluids... diff fluid was tan and smelt bad.. tranny fluid red...ish.....
i think thats all i got... any expertise is awesome as always... thanks!
-drew
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 03-14-2006, 08:01 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
You said "wheels", plural. Is this correct? This determines weather the AWD is working correctly. If only the front spin and then the whining happens and the front wheels stops spinning because the back wheels engauge the C solenoid might be going bad.
If front and back wheels spin and there is a whining noise then that is above me. Harvey help.
How old is the tranny fluid?
Front diff does smell bad. If I remenber right it takes GL-5 80wt, front, GL-5LS, rear, thick and stinky.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 03-14-2006, 10:10 AM
i'm almost positive i can get 4 wheels to spin... and the last shop it was at confirmed my awd was at least working..
'96 Saab 900 turbo
Old 03-14-2006, 11:44 AM
You need to know which wheels are spinning when it makes that noise. The sound could be the AWD clutch trying to catch the rear wheels up to the front.
Old 03-14-2006, 01:17 PM
could also be that you are only spinning one front wheel. This will cause the open differential to whine as you are rubbing metal to metal of the spyder gears in the carrier
Old 03-14-2006, 01:57 PM
i think thats it... tom
hey, i'm thinkin that might be it... is that due to some failure or age? or is that just how it works??? what am i lookin to have to replace?
thanks everybody!
-drew
'96 Saab 900 turbo
Old 03-14-2006, 02:13 PM
SHouldn't need to replace anything, try to avoid doing it though or else your differential will probobly puke out
Old 03-14-2006, 03:02 PM
relief
well thats relieving... now i'm gonna tackle the valve cover gaskets...!
-drew
'96 Saab 900 turbo
Old 03-14-2006, 03:07 PM
As Tom says, it seems like one front wheel is spinning. The noise is the differential gears working. These gears are spur gears that are not very quite. That in itself is not a problem, but the fact that the front is spinning. is a worry. It would appear that the AWD is not engaging, or not engaging fast enough to prevent the front from spinning.
You say that the 'shop' confirmed that the AWD was working. Did they just put it on a lift, and see the rear wheels turn, or did they do the test under wheel spin load? I would think that the AWD is not working properly, and the front diff is at risk.
