Old 03-04-2006, 04:55 PM
92svx95 92svx95 is offline
Doing a 4.44 swap soon
Hey i was looking around to do a 4.44 swap and i was wondering would a 1999 outback awd automatic 2.5L transmission work in doing this conversion???
Old 03-04-2006, 05:00 PM
chaswiggins chaswiggins is offline
I was under the impression (96-early 98) Legacy Outback 2.5 auto trannys were 4.44s. ?
1992 Subaru SVX
2000 Daewoo Lanos
2001 Parts in my garage.
KYR SCCA member and Rally Driver wannabe.
Old 03-04-2006, 05:06 PM
thats why i asked cus i was under same impression... anyway on finding out??
Old 03-04-2006, 05:44 PM
Yes,
The 96-98 EARLY 4EATS work with our TCU's.
I now have a thread in my signature that should help.
Old 03-04-2006, 05:50 PM
alrighty, dam i found a great deal on a 99 with 40k on it.... tosses that idea out... looks like i might have to drive to LA(313 miles) to get my 97 outback tranny. If that guy doesnt have a matchin rear end anyone know of a source to find one(LSD of course)
Old 03-04-2006, 05:56 PM
I really am not trying to bring you down, but,
There are no LSD rear ends that fit our SVXi
You will have to swap out the LSD from the SVX and install it into the donor rear end, sorry.
Old 03-04-2006, 06:00 PM
hmmmmmmmmmm . lol that makes more since. is that process hard to do??? im down to get my hands dirty
Old 03-04-2006, 06:07 PM
Thumbs up
so that is what i have to grind in the rearend. u have some useful information in your locker. thx.. back to pricing out everything i am going to need and gettin all the tools needed.
Old 03-04-2006, 06:20 PM
The process is not that hard, but a little unpredictable.
In the thread in my signature, I explain how to do it, but,
Even with a properly set up rear differential, backlash of 0.0039-0.0079" and a correct and proper pattern, and good, fresh, clean, 85-95 oil in it, it should not, but might whine
I have three 4.44s in my driveway, and have built about 17-20 others, and could STILL build one that makes noise!
Wiskey, Tango, Foxtrot!
Old 03-04-2006, 06:32 PM
nice information... this caught my eye.
NOTE, if you are just upgrading as a mod, use your SVX torque converter.
If your transmission is bad, then your SVX torque converter is probably contaminated, and you can use an 96-98 Legacy Outback torque converter.
They have been used successfully in the past.
DO NOT USE an Impreza torque converter! (unless it came from a 2.5 RS)
It is probably far to small for SVX HP levels.
How would i check if the torque converter is contaminated? how much should a 96-98 Legacy Outback torque converter if the transmission i buy doesnt come with one... i am pricing everything out and worse case scenario i wanna be prepaired.
Old 03-04-2006, 11:02 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Are you talking about the rough life banana from morgantown?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 03-06-2006, 08:31 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
My rear end seems to whine under load, but it's really hard to tell until I get the exhaust finish and new rear bearings.
And I used the legacy torque converter and it works perfectly fine.
Old 03-06-2006, 03:27 PM
=] I found a 97 outback transmission... pretty local to me. how would i check if it is a 4.44??? i got the ID# TZ 102Z2CBA-DT . transmossion supposed to have 70k miles on it and he is offerin 650$. and he is only 30 miles from my home.
Old 03-06-2006, 03:52 PM
Budfreak's Avatar
Banned
That is a 4.44. Not a bad find especially so close by. Good luck.
Old 03-06-2006, 03:54 PM
thanks buddy hopefully it comes with a torque converter =]
