Old 02-26-2006, 03:36 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Originally Posted by Ricochet
Theirs was digital.. it was on some big cart that he had to push outside.
Then it was probally to slow to catch the voltage changes. Try a computer friendly analog meter and see what happens.
Old 02-26-2006, 03:41 PM
Budfreak's Avatar
Banned
Then it was probally to slow to catch the voltage changes. Try a computer friendly analog meter and see what happens. You'll probally see the needle bouncing up and down to the beat of the pulses which would indicate crapping alternator or voltage regulator. Good luck and keep us informed.
-Jason
P.S. My connection is bad today and it made me screw up and double post.
Old 02-26-2006, 05:19 PM
Flickering lights.
If the flickering is fast, then it is more likely to be a wiring connection or ground connection. The regulator can produce this type of thing, but it won't be fast, as the battery is in the circuit and its voltage won't change that fast. A faulty connection, either in the supply or ground wiring, can change resistance fast, to produce this type of fault.
Digital meters can read fast changes, depending on the refresh rate. Cheap ones are slow. The better ones can read, and record, instant maximum/minimum voltage changes.
I don't think it is the regulator.
Old 02-26-2006, 05:28 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
They don't oscillate "fast" though, it's more like a 1 2 3 4 1 2 3 4 (for you drum players), slow and steady..
Brian
Old 02-27-2006, 12:13 AM
Budfreak's Avatar
Banned
Does the pulse speed change with RPM's? I'd have a hard time believing it to be a bad connection when it was doing the same thing before and after the wiring mod. How did the terminals look on everything?
