Old 02-24-2006, 09:33 AM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Just how worn down?
Just how worn down does one tire of the four have to be in order to warrent a replacement for all four. I recently blew one, and im not sure if they are still young enough to replace just one instead of all four (so that I dont mess up the tranny with uneven rolling diameters) Does anyone know what the tolerance for it is? Thanks!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 02-24-2006, 01:09 PM
SubaSteevo's Avatar
No longer blue member
About a year ago I asked a similar question, the response I got was that Subaru recomends no more than 1/4" difference in diameter between the tires.
http://www.subaru-svx.net/forum/show...ighlight=tires
-Steve
01' MSM Lexus IS300
Old 02-24-2006, 10:51 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Another option? You have 18"?!
Buy two new ones same as the current ones you have, put them at the front.
Then take out one of the old tires for a full size spare at home?!
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-25-2006, 01:32 AM
That may work, but they still need to be very close to the same size.
