Old 02-15-2006, 02:34 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
How do I remove the windshield wipers
I took off the little rubber caps, took off the nut underneath, but was lost on what to do next.. they wouldn't budge.
Brian
Old 02-15-2006, 02:36 PM
Flip up the spring part that you normally flip up to clean the winshield so that the spring isn't putting pressure against the glass, then gently wiggle the arm and it will come loose.
Old 02-15-2006, 02:46 PM
Ricochet's Avatar
I brought some ham.
I did flip them up and try, guess I didn't wiggle them enough.. Thanks man I'll try again.
Brian
Old 02-15-2006, 03:15 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Try a little WD-40 if you can't get them off. Mine were rusty but I got lucky and they popped right off. Good luck.
Old 02-15-2006, 04:46 PM
Ricochet's Avatar
I brought some ham.
I'll try tomorrow, got dark out all of a sudden. I had a busy day with her today doing other things.. did the alternator wiring upgrade, swapped out for a jdm hood badge, and washed her. Reason I'm taking off the wipers is so I can repaint them black because they're rusty. She's getting a nice little makeover
Now how do I take off the rear one?
Brian
Old 02-15-2006, 06:51 PM
The nut is in the same place, but rather than the rubber plug covering it, there is a plastic sheath that hinges over that section of the arm. You'll figure it out when you see it....
