Old 02-12-2006, 09:19 PM
Wocketman Wocketman is offline
AWD problem
I think I brought this up in an earlier thread, but can't find it at the moment...
My AWD doesn't seem to be working properly (big problem taking off in the snow!). Took it to a dealer for diagnosis and what they came up with was "error code 11 was present in memory"--"Line pressure duty solenoid malfunction".
They sail more diagnostic time was needed....and that they needed to pull the tranny. Ouch!
Any other suggestions? All ears.
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 02-12-2006, 09:25 PM
n00b on demand's Avatar
most probably your solenoid C failing....80 buck part from subaru parts.com
Do the rear wheels kick in at all or are your fronts just spinning?
Old 02-12-2006, 09:46 PM
They SEEM to kick in sometimes, but the fronts (or one front) will often spin for some time (seems to be mostly at low speed) without the rear kicking in.
Where is the Solenoid C located? I'd be happy to try that first before digging into the tranny to get at the duty soleniod!
Bruce Schwab
www.bruceschwab.com
Old 02-12-2006, 09:58 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
All 3 solenoids are in the control assembly located above the transmission pan. I get them mixed up, but I'm almost certain sol C is one of the two solenoids you can get to by removing the pan without removing the transmission.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 02-13-2006, 06:03 AM
Thanks Electro!
Bruce Schwab
www.bruceschwab.com
Old 02-13-2006, 06:14 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Is it labelled at all? What exactly does it look like? Got any pictures? Anybody?
Brian
Old 02-13-2006, 03:15 PM
The C Solenoid is located in the rear section of the transmission. It can be removed without pulling the box. You need to buy the C Solenoid/transfer valve assemble, and a set of clutch plates. Fit the lot to ensure that it is fixed.
Looks like this;
Old 02-13-2006, 03:23 PM
For reference: Code 11 = Solenoid A failure...nothing to do with AWD.
Usually it's caused by a failed resistor (between the battery and fender)
Old 02-13-2006, 03:44 PM
Ricochet's Avatar
I brought some ham.
Thanks for the pic, but do you have one on of it on the car?
Brian
Old 02-13-2006, 04:02 PM
That's a trick question. You have to take the back of the tranny (extension) apart to get at the solenoid.
Old 02-13-2006, 04:08 PM
No, mine is the Euro epicyclic AWD, same place, same things, different look do a different job. If you look at the pic, you can see the Transfer valve position, and the clutch, they are the same, you don't have the gears.
Old 02-13-2006, 06:15 PM
Uh...just a hunch (and just my luck?)...is Soleniod A the one of the three that is the hardest to get at?
Bruce Schwab
www.bruceschwab.com
Old 02-13-2006, 06:28 PM
"A" is by far the easiest.
Old 02-15-2006, 08:46 PM
Ok...next monday we are pulling the back of the tranny out to check out the Soleniod C and the clutch it engages. We think that the transfer (to rear axle) clutch might be burned out. Will report back on success or failure.
Bruce Schwab
www.bruceschwab.com
