Old 02-10-2006, 05:55 AM
Tcat55371 Tcat55371 is offline
What controls the auto drivers window?
My power windows work fine but the auto down feature does not. My ex has auto up and down by just hitting the button once. The switch in the SVX says auto on it but it only works if you hold the button. Is this controlled by the switch or on the motor?
Old 02-10-2006, 07:47 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Mine doesn't work either. What year and model SVX do you have, mine is a 92 ...........
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 02-10-2006, 08:24 AM
The problem is in the switch itself. There is a plastic tab that is broken or worn that won't let the auto function properly.
In the 92 SVX, the windows had the auto UP and auto DOWN feature. If you pushed or pulled on the switch button completely, you could feel it catch. On the later years, for safety reasons, the switch was modified so that only auto DOWN was available.
It is very easy to replace the switch. Check out posts for speaker replacement to show you how to remove the door panel and unplug the switch. There are posts about this switch and photos as well if you search.
1992 switch (Auto UP and auto DOWN) P/N 83081PA010
(Auto DOWN only) P/N 83081PA070
around $100.00 from subaruparts.com
Old 02-10-2006, 09:33 AM
dwd1985 dwd1985 is offline
I just fixed my window switch. I got one from Freakcustoms while he parts his SVX out, and the procedure is very simple. Many of my buttons had gotten loose, and one had even come off, and I couldnt put the passenger side window up, only down. So I unscrewed the top button portion (the black switches themselves) off of the electronic controller portion (the white plastic block), and then combined it with my good electronic controller, to make one functioning unit. Removing the door panel is very easy, only 6 screws that need to be removed. The whole process took me about 45 minutes.
Old 02-10-2006, 05:39 PM
Hey,
Thanks guys. Mine is a 92 also. It doesn't really matter but I was wondering how to go about it. It hasn't worked since I got it. I wonder if that would be covered under my used car warranty. Only prolem is I have a 100.00 deductible but it would get me out of having to do it.
