Old 02-08-2006, 08:20 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Battery Died - Twice
My battery dies on me two nights in a row. No lights were left on or anything. Voltage of battery down to between 3-5 volts before jump starting. No problems before. Temps did drop recently below freezing. My Subarus have never liked this and I can depend on at least one doing this. Suprised the SVX did it. Anyone else this happens to when the temps drop below freezing?
Kevin Thomas
***R.I.P***
Old 02-08-2006, 08:56 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure your alternator is working. Use a volt meter on the alternator or buy a volt meter that plugs into the cigarette lighter.
Old 02-08-2006, 09:45 PM
If your battery is going to go, it will be when the temps drop below freezing.
Old 02-08-2006, 10:24 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
If that's the battery problem, that'll be the most simplest solution.
I assume no SVXi will be able to leave any lights on when the key is pulled from the ignition? (except the parking lights and hazard light)
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-09-2006, 12:43 AM
check the sun visor wires and make sure they are not causing a short and draining the battery
Old 02-09-2006, 07:50 AM
awdsvx awdsvx is offline
Battery
Also make sure that the alternator belt is not slipping. If is slipping also make sure there is tension on the belt, but I would just go ahead and change it out anyway just to make sure it is not the belt or the tension. It cost me $ 14.00 for a Good Year Poly-V Flextra #345k5 part number.
Just yesterday I finally had to change out my battery and a blown fusible link in the fuse box that is located in the engine bay.
Here is my orginal post:
http://www.subaru-svx.net/forum/showthread.php?t=24469
Old 02-09-2006, 09:04 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Never had a problem with that battery over the two years I owned the car. Did you hook up the connector for the trunk light? I disconnected it b/c it would drain the battery overnight.
2006 Steel Gray WRX TR (sold)
Old 02-09-2006, 09:58 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
Me To
Yes I Have Had The Same Thing Happend To Me Before. I Just Got A New Battery And Ran The Car For About 30min A Day. Just Keep Start Up The Car Every Day. But If It Is Not The Battery It Might Be The Spark Plugs.also Look At Your Fushes And See If They Are Ok.
Old 02-09-2006, 11:10 AM
Kevin,
either the car just misses Chi ke, or the constant polishing he used to do, constantly, would somehow charge the battery through static electricity.
Old 02-09-2006, 11:12 AM
Originally Posted by svxfiles
Kevin,
either the car just misses Chi ke, or the constant polishing he used to do, constantly, would somehow charge the battery through static electricty.
hahahaha Ba...ZING!!!
Old 02-09-2006, 07:20 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Kevin,
Good point! I haven't driven it much at all since the purchase. Maybe I should polish it up or something. Just waiting for a reason to drive it I guess. I did take it up to ***mph the other night and recorded it. I was.....trying to escape a road rager....yeah...that's it. Actually it was an experiment to see the limit of the 4.44s. Apparently, I need the Autobahn to find out.
Kevin Thomas
***R.I.P***
Old 02-12-2006, 12:06 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
I do not know if this has anything to do with the battery dying but the battery's CCA (Cold Cranking Amps) was 460. The CA (Cranking Amps) was 575.
I purchased a battery with a CCA of 800 and CA of 1000. Perhaps that should help things along in the colder temps.
Kevin Thomas
***R.I.P***
Old 02-12-2006, 12:22 PM
Did you take that battery out when you sold the car and put in another old one?
Old 02-12-2006, 12:40 PM
Chiketkd's Avatar
Ha ha! No. It still had my old Interstate battery.
Myxalplyx, the battery you purchased is a serious monster! Dayum!!!!
-Chike
Old 02-13-2006, 12:33 PM
800CCA is probably the minimum I would use here.
