Old 02-06-2006, 02:02 PM
bcpianoman bcpianoman is offline
Windshield Fogging Up
Has anyone ever had a problem with their windshield fogging up excessively when you activate the defrost? Mine just started getting foggier and foggier when the defrost is on. I strongly suspect that the heater core is leaking and the coolant is evaporating in the duct work and then condensing on the windshield.
Is it a big job accessing the heater core?
Old 02-06-2006, 02:13 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Stop breathing heavily in your car.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 02-06-2006, 02:20 PM
10,000 comics out of work and look who's trying to be funny!
Old 02-06-2006, 02:37 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Try cleaning the inside of the glass and try using the A/C to take up the humidity.
Old 02-06-2006, 03:05 PM
The glass is already clean and it's too cold outside for the A/C to kick in. It's fogging up way too fast for there not to be a source of moisture being introduced into the system.
Old 02-06-2006, 10:49 PM
That is what my Outback is doing and I can smell antifreeze. The heater core was leaking in it. I put some stopleak in it and it helped. I will replace the core this summer.
Old 02-07-2006, 01:03 PM
As long as it's above freezing the A/C will work while the defrost is on.
Old 02-08-2006, 01:14 PM
Hangtownsvx Hangtownsvx is offline
Yes, it is time to fix the heater core. I had a mechanic do it last year on mine.
