Old 02-05-2006, 12:35 AM
SubyLuver SubyLuver is offline
Loyal Subie-ist
Send a message via MSN to SubyLuver
Door sensor
I know you have heard this a million times, but my seatbelt wont move forward when the door opens.... I noticed also that the dome light doesnt always go on, and the indicator on my dash that shows the door is open doesnt light up. Where is the sensor that is all related to?
Subyluver
'92 Subaru SVX Ebony 216k miles
(Magnaflow Custom Cat-Back, ES Stablizer Bushings, Permacool Relocator, 2.5RS FPR, SS Brake Lines, EBC Green Pads, Raceconcepts D/S Rotors, Pirelli P-Zero Nero M&S)
(To-do list Koni Struts & Springs lacking funds)
Old 02-06-2006, 12:36 PM
It's part of the door latch located inside the door.
Old 02-06-2006, 07:39 PM
Loyal Subie-ist
Have to remove the door panel then huh? DOH I hate doing those... oh well will check it out when I install speakers...
Subyluver
Old 02-07-2006, 12:45 PM
It's probably just a loose connection. For getting the inner door panel off just do a search (covered countless times). Just check all the connections by wiggling or replugging them. Might be a good idea to have a multimeter to test continuity.
Old 03-20-2006, 06:44 AM
Antigenus's Avatar
Antigenus Antigenus is offline
Send a message via AIM to Antigenus
I have this exact same issue, the door opens and no seatbelt movement or dome light....Im gonna tear open to door and play with the wires today myself.
Matt - Akron, OH
And then what???
Old 03-20-2006, 07:11 AM
zavikan zavikan is offline
It is extremely doubtful there is anything wrong with the door actuator switch. My guess is the wires to it have come loose as well.
On my old svx, I had the same problem. Opened the door up, felt down, and the wires were not even connected anymore But then after I plugged it in, I found out my seatbelt switch wasn't working right either
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
