Old 01-26-2006, 05:48 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
exhaust
Can't seem to find any exhaust systems for the SVX. Any suggestions where to look?
Old 01-26-2006, 06:14 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
You can start with Motorsport Warehouse. They're good people.
http://shop.store.yahoo.com/svx-moto...ies/index.html
You live anywhere near Shohola, PA? That's where I grew up.
Gene
Gene and Ben
Old 01-26-2006, 06:23 AM
Htownsvx Htownsvx is offline
Send a message via Yahoo to Htownsvx
you can you the same muffler flowmaster or any comany make for the chevy camaro i would not go any bigger then 2.5 in pipe.
i used the flow master muffler of ebay got it for 69.99 it was like 70 something with shipping and i got a 2.5 high flow cat for about the same price this guy i know did the install for $200 and thats from the headers down
01 subaru legacy 5sp
97 J-spec kl-ze 5sp ford probe
the best of them all the 92 lsl svx amost 100,000 mile
Old 01-26-2006, 08:46 AM
mbtoloczko's Avatar
sans SVX
Besides the Stebro and Flatt system, there aren't any "bolt-in" exhaust systems. If you don't want the Stebro or the Flatt, then your only option is to buy parts and have a reputable muffler shop weld it up. There are tons of suitable mufflers and accessories available for great prices. If you are just looking for better sound and a few HP, the easiest to do is to make a cat-back system. For an SVX cat-back system, 2.5" OD tubing is appropriate. (There's no point in going higher because the real constriction are the catalytic converters.) The least expensive way to go is to use a Camaro-style cross-flow muffler. Both Magnaflow and Flow Master make ones. A resonator is also needed. Magnaflow has a nice one that's perfect for the SVX. And then you just need to pick some exhaust tips.
Mychailo
Visit my locker
Old 01-26-2006, 08:53 AM
Tcat55371 Tcat55371 is offline
hmm
What do you need the resonater for? Mine has a loose baffle and I was just going to remove it with a straight pipe
Old 01-26-2006, 10:10 AM
mbtoloczko's Avatar
sans SVX
A resonator will make a better exhaust sound than using a straight piece of pipe. And it is possible that it will offer better performance over a straight pipe by causing sonic reflections that will improve exhaust scavenging from the cylinders at around 4000-4500 rpm.
Mychailo
Visit my locker
Old 01-26-2006, 10:35 AM
The stebro is nice, but I have a better suggestion. PM SubaFreak to see if he will make you a custom system. I got mine done front to back for a steal, with all Magnaflow parts. My car sounds really quiet at idle, but like an indy car on the highway.
Old 01-27-2006, 11:34 AM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
I am in the process of getting another exhaust set up done to my car. 2.5'' from headers to tips. I'm not sure if I will be using any cats or mufflers. Gotta see what taxes bring to me. I might use the stock cats and skip the muffler.
The way my car sits now is both pre cats and thats it. I took off the Y cat so I could true dual and sidepipe the car. But after many failed attempts, the side pipes came off.
With just the pre cats, the car sounds awesome at idle and sounds like a built V-8 under acceleration. It just gets a little too loud inside the car at the moment.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
