Duty Solenoid C Code
SO i pulled a duty solenoid c code from my svx (97 lsi) the other day. Can anyone point me to a thread on a duty solenoid c how-to? i have done some searching without much luck. i have determined that my awd does work. so is it possible that the c solenoid is only sometimes failing? would that mean the solenoid is going bad or should i start by diagnosing something else?
i hope i don't sound like an idiot here, but i am very AT ignorant. i have figured out basically what the c solenoid does. i am just trying to figure out how i know if i need to replace it. is there any wiring that could be damaged causing the malfunction? any help would be appreciated.
-Ryan My first Subaru, 1997 LSi #004 - SOLD! Currently driving: 2002 Honda Insight, > 60MPG! |
It means the TCU is getting an invalid responce from that circuit. Some have found a wire at the solenoid ready to fall off and only making sporadic contact.
Does your AWD engage quick and smooth or does it clunk or bind? Do your front tires spin first before the rears kick in?
god I'm having this same problem.. if somebody would kindly post a picture of exactly where this wire is I'll beat up your mother in law free of charge.
Brian |
The "wire" is inside the tailshaft housing... you will have to do a little dirty work to get to it... but if your that far, you might as well replace the selonoid while your there.
1995 Subaru SVX -Accel Green Filter * -Flowmaster Exhaust -ECU Stage 1 Chip * -Alluminum Drive Pulley * -Stage 1 Shift Kit -Small Car Clear Lenses and Corners -1997 SVX Grill -17" X 7" Enkei Shoguns *Thanks Dayle! (SVX Motorsports) 1987 Pontiac Formula 350 -Enough (Once I put it back together again) |
Thread Tools | |
Display Modes | |
