Old 12-28-2005, 05:22 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
reading codes
Where or how can I pull up some codes? My car doesn't blink any lights for codes to read and my ABS light has been on for awhile. All the mechanics I've went to can't read codes on older cars. Do I need to buy something? Is there a shop I can go, like Sears, Pep boys, Midas, etc.?
Old 12-28-2005, 09:50 AM
If you go to the helpful How-To Documents and look there, you would find out how to do it. Here is the link for all of the codes. Good luck.
http://www.subaru-svx.net/photos/user.php?How-To|14263
Old 12-28-2005, 11:13 AM
Earl, your link is missing.
Both the how-to lockers and the SVXipedia on http://svx-iw.com list codes and instructions.
Old 12-28-2005, 05:04 PM
Ooooops Here it is.
Old 12-28-2005, 05:06 PM
Ooooops Here it is.
Ooooops Here it is.
LInk to the Code How-To Doc.
Old 12-28-2005, 05:20 PM
Ever hear of the Edit button?
Old 12-28-2005, 06:16 PM
intelisevil's Avatar
<<<Alcyone
Earl likes to say "Ooooops Here it is."
Dan
Old 12-29-2005, 08:30 PM
dannmarr's Avatar
I work for my SVX
I need to read the ABS codes, not the engine codes. My ABS control unit does not work, so I can't get a code. What else can I do?
Old 12-29-2005, 11:49 PM
Yes I have and I have even seen it. I have found that people don't go back up to the previous posts to see if they were edited. They just continue down the page reading the next few posts.
I will try to vary my expressions even if I don't use the edit button.
Old 12-30-2005, 07:31 PM
dannmarr's Avatar
I work for my SVX
I pulled up code 11 (crank angle sensor). Where is this? What does it do? Anyone have a photo of this? Any info?
Old 12-31-2005, 01:58 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Dannmarr...... Earthworm has the ABS codes somewhere... I haven't looked yet, but when I had problems, there were about 11 codes (abs codes), and you have to read them from your blinking ABS ecu under your passenger seat....I believe you have to drive at least over 35 mph for at least 1 minute and then come to a stop and see what the ecu code is from the blinks.
1995 Subaru Svx L / AWD
Old 12-31-2005, 02:02 PM
msvx95's Avatar
It's just a phase
Ok, of course I look after I typed above:
The codes are there from the link above as well.....There are 0-16 codes and you have to drive at least 19mph for 1 minute to read the codes......Just don't check it as you are driving....that may get tricky
Old 12-31-2005, 02:48 PM
dannmarr's Avatar
I work for my SVX
Thanks for the reply, but I've tried everything. It seems that my ABS ecu is not working. How else can I test this ABS problem? I also need to know about code 11, where, how,what etc.
Old 01-02-2006, 12:16 PM
You can only get the codes from the ABS unit. Can you borrow a replacement unit from a kind and helpful forum member?
Usually there's a bad ground or water in the ABS unit.
