Old 12-18-2005, 02:20 PM
Originally Posted by intelisevil
He can't be that bad of a person . . . he drives our favorite car!!!
Dan
hehe, I am with you my friend, but anyone driving an SVX must have either a face or a face... This new guy has faces all around
Old 12-18-2005, 04:03 PM
I used nothing but and for a while.
Originally Posted by DarknessofDeath
i was wondering what it was. if it was worth doing or looking into. i saw some signatures with the mod listed and took a look at the how to doc. tha'ts all.
i dont even think it would be a performance increase.
To me this doesn't seem worthy to be listed as a mod, and any performance increase or real effect is negligible.
But it also doesn't hurt.
The only reason I still have mine bypassed is because I can't get the damn brass thingy out, and I am far to preoccupied with other failing elements of my vehicle.
Old 09-20-2006, 06:47 PM
gtdanielgt's Avatar
gtdanielgt gtdanielgt is offline
I miss my VR-4
Send a message via Yahoo to gtdanielgt
Yay! Glad I found this thread... Time to resurrect it... Ok has anyone seen any type of beneficial anything from doing this 'mod' ? I live in Arizona so I'm pretty sure i could run this all year round, except maybe when I go up into the mountains in the winter. But my question is, by re-routing the coolant, does the car run a scotche cooler or accelerate smoother, anything at all? Or was someone just bored one day and realized this was something you could do for fun...
thanks all
Insert Witty Quip Here...
No more subie
Current Cars: 96 Chevy Caprice Impala SS clone
93 Chevy Full-size blazer
Soon: 2002 Honda CBR 954RR
Old 09-20-2006, 07:44 PM
immortal_suby's Avatar
Thread Killah
I tried it and then put it back to stock a short time later. I didn't notice any difference with this mod.
Locker Link
2015 BRZ Limited 6MT
Old 09-20-2006, 09:26 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
thanks all
I noticed a difference in the way it runs and accelerates off the line. It seems to be smoother with less hesitation. I've seen dyno runs from cars that have seen up to 8 HP from bypassing the coolant to the TB.
Old 09-20-2006, 10:19 PM
gtdanielgt's Avatar
I miss my VR-4
ahhh very good to know... Thanks Bud
Anyone have any idea of at what the ouside temperature would have to be before it starts causing problems with this mod in place? I would assume somewhere under freezing point.. 32 degrees... maybe like at 20 degrees or so?
No more subie
Old 09-20-2006, 10:24 PM
Depends on how fast you drive.
I've tested this out in sub zero weather and it has not affected my car at all but for one instance on the highway.
I was cruising along about 70 (road was dry), temps were just a little below zero, I let off the gas, gas did not let off for a second.
I imagine driving a good distance could very well freeze your TB open but radiating engine heat will keep it clear most of the time.
Ummmmm.... I did not have phenolic spacers at the time.
So right meow my TB is more likely to freeze and less likely to thaw when frozen. I will find out in the coming months what effects are to be had.
Old 09-20-2006, 11:07 PM
Hose92SVX Hose92SVX is offline
I don't know what the tempature has to be in order for frost and ice to vuild up. This car and this heated TB is all new to me but I know in small planes they have carb heaters and the carbs can ice up in tempatures as high as 50 degrees, but I think that's because of pressure gains and losses. associated within the carb and the altitude. Good question.
Old 09-20-2006, 11:43 PM
Budfreak's Avatar
Banned
I don't run mine when the temp drops below 40 degrees. Due to the pressures and so on in the intake the throttle bodies can begin to freeze at temps above 32 degrees. I got on the throttle one night when it was between 35 and 40 degrees out and the throttle didn't let go for long enough to worry me when I let off.
Old 09-21-2006, 12:14 PM
dmnknightomega6 dmnknightomega6 is offline
I just Coat My TB With oil and the cables to prevent the sticking. WD 40.
Old 09-21-2006, 06:21 PM
Thread Killah
this mod is about as effective as the "improved throttle response" throttle cable adjustment "mod".
Locker Link
Old 09-21-2006, 07:58 PM
RSVX RSVX is offline
Network Design Administrator
Leave Chike and his winter "mod" alone!
Life is a game. Play to win.
