Old 12-16-2005, 11:01 PM
davew833 davew833 is offline
Today's Simple Lesson (O2 sensor)
I've been getting a Check Engine code 32 for the past week or so, so today I did quite a bit of research on this forum and elsewhere about how to replace the right side O2 sensor, where to get a new one, whether to get one with an OE connector or a universal and splice the old one on, etc. Well, I got under the car this evening to further evaluate the situation and found out THE SILLY THING WAS DISCONNECTED AT THE PLUG! Not sure how it happened, expecially given the number of people here that have said how hard they are to unplug, but it was an easy fix anyway...
Old 12-16-2005, 11:07 PM
First rule of troubleshooting: make sure everything is plugged in whre it should be.
Old 12-17-2005, 10:19 AM
Second rule of troubleshooting: make sure everything is plugged in whre it should be.
Old 12-17-2005, 11:09 AM
Another handy rule I learned a long time ago.
If your car has been running without problems and all of a sudden starts acting strange and erratic... Think back to the very last thing you did.
Once I wired up a 12 volt outlet in my trunk and only one strand of the 12V power wire had somehow worked loose and was touching ground.
