Old 11-29-2005, 09:24 PM
spinn360's Avatar
spinn360 spinn360 is offline
AWD not working
So it finally snowed and I got to drive my SVX for the first time in snow. Only it sucks theres no grip front end just spinns and the rear at first does nothing. I live 30 miles from where I work so on the way home I experimented the rear end would kick in with a loud thump/clunk only when I really got on it and my front wheels spun. I am driving my xt6 right now I love my fulltime four wheel drive manual. I have read many posts just like this, and I believe that it could be the clutch packs (but I dont really think thats it because they looked fine when I worked on tranny), or it could be that the solenoid c is sticking??? but every post I find says just that is there a how to on changing the solenoid C because I cant find it. Or does anyone have any idea what I should do beside driving the car off a cliff.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 11-29-2005, 09:43 PM
svx!!!!
weak sauce...awd and fwd are NOT the same...hahahhaha...noob
Old 11-29-2005, 10:15 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
You're a bigger n00b than him. You can't even use quotes correctly?!
-Chike
P.S. Nice to see you back-tracked and edited your post.
2006 Steel Gray WRX TR (sold)
Old 11-29-2005, 10:21 PM
spinn360's Avatar
Wow That Really Helps Thanks for all the technical advise.
Old 11-29-2005, 10:25 PM
spinn360's Avatar
No Sh!t I had no idea you've really opened my eyes but I would rather have 4wd then an AWD that doesnt work!
Old 11-29-2005, 11:33 PM
SubaSteevo's Avatar
No longer blue member
Spinn, from what I've heard, if Solenoid C is failing it will cause either a permanent split, I don't think you would experience the kick as you describe.
Some people have had success fixing an AWD binding issue by driving tight circles in a parking lot, and on that note I will refer you to this thread for more technical information I don't understand
http://www.subaru-svx.net/forum/show...id+replacement
-Steve
01' MSM Lexus IS300
Old 11-30-2005, 11:39 AM
The "C" solenoid is slow to respond. Mine would do this as well. Either the solenoid is sticking, there's a lack of pressure issue in the tranny or the clutches themselves are causing the problem.
Old 11-30-2005, 12:23 PM
Pearlywhites1992
You may have found my thread from last week with the same title.
Subaru called and said Solenoid C is working and that the clutch pack is definitely to blame. Then they called back and said the propeller shaft
was also broke. I never heard a snap, and now wonder if I ever had AWD
since owning the car. Seems to go through front axles a lot, could that be why? I'm probably looking at about $1200. But did I mention I have a nice loaner?!
Old 11-30-2005, 02:33 PM
Slow to respond.
As Dave says, the transfer clutch is slow to act. Either the plates are very worn, or the C solenoid/transfer valve is sticking. My guess is the transfer valve. as you say "it looked ok when I worked on it".
The C solenoid/transfer valve assemble, is fitted in the rear housing, you have to disconnect the wire to remove the housing. It is supplied as a complete assemble, not too dear.
ps. I would not allow the clutch to clunk, as it can break the clutch drum off the transfer gear.
Old 11-30-2005, 07:14 PM
Manarius's Avatar
Manarius Manarius is offline
NOT A GOOD IDEA. You'll end up with a burned tranny that way. You'll just burn the **** out of the center differential and then your car won't go at all.
-Jason
-Obi Wan Kenobi
Old 11-30-2005, 07:50 PM
spinn360's Avatar
Hey thanks guys. Do I have to order the solenoid from subaru or where should I buy from and does anyone have any idea on the price. Also Dont worry I am not driving it anymore, and I only did it a couple of times. Hopefully it'll hold up, probably broke something though with the luck I've had with this car.
Old 11-30-2005, 08:34 PM
If I had a 4wd XT6 again I'd be parking the SVX all winter.
The only thing the SVX beats the XT6 at during winter is cold starts.
However, if you have no grip at all you are pressing the gas too hard or have crappy tires.
My AWD is just about bunk and spins tires all over the place but a light throttling at the green was all I needed to keep some b!$(# in a huge new Ford from cutting me off today, and to date I have never lost control 'cept for last winter when I did some rallying.
You might as well order the solenoid and whatever comes with it from Subaru unless you can find it for cheap on some website or someone is parting out a low mileage SVX.
Oh by the way,
guys,
DON'T FEED THE TROLLS.
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
My car does the same thing! I just don't have a clunk though. It transfers to AWD pretty smoothly but it's slow to do it. Will raising the resistance on the tranny resistor help?
Old 11-30-2005, 08:36 PM
That has nothing to do with it.
Yeah and my car did the same thing soon after my tranny was rebuilt 15 months/ 9200 miles ago. It clunked on hard right turns from stops up hills.
Now it doesn't clunk.
Something broke.
Old 12-02-2005, 05:08 AM
Pearlywhites1992
As usual, my car feels like brand-new again after coming home
from "mama's house" (the dealer). $1650 should make things
better. New clutch assembly, prop (?) as well as the second
and final 02 sensor...clearing the CE light. It's snowing pretty
good today so I'll make sure they fixed it!
