Old 11-27-2005, 11:00 AM
Manarius's Avatar
Manarius Manarius is offline
Originally Posted by POWER on demand
Even the manual says on cold mornings you may need to do this.
I've started my car at -22F without pressing the pedal...and that's with heavy weight oil. As far as I understood, you should NEVER press the pedal during start up.
-Jason
-Obi Wan Kenobi
Old 11-27-2005, 11:46 AM
kuoh kuoh is offline
Never say never. While it is "normally" not necessary to use the gas to start a fuel injected engine under normal conditions, there are still occasions when it is necessary. All it takes is one good flood to lock you in your parking spot cranking away untill the battery finally dies. Just being cold isn't usualy a problem, but cold and wet is sometimes a difficult combination to overcome, as one of the early TSBs for the SVX regarding injector icing would attest to.
KuoH
Old 11-28-2005, 12:40 PM
I've started in -40° and never touch the gas. The only time I had problems starting was when the engine temperature sensor failed.
